Go to Post if you need a hammer you use a hammer and not an oscilloscope. - Andrew Schreiber [more]
Unread 07-02-2016, 07:28
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Tower wall surface/ suction cup
Anyone that has seen an actual field: is the surface of the tower smooth enough that a suction cup would hold well to it?
Unread 07-02-2016, 07:31
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Tower wall surface/ suction cup
It's completely smooth, but I don't think I would count on it being weight bearing. It's pretty thin polycarbonate that is held on to the frame behind it with some brackets that are a loose fit on the frame according to the drawings. I would expect it to have quite a bit of wiggle and flex and certainly wouldn't try to hang the weight of a robot off of it.
Unread 07-02-2016, 07:59
FRC #6054 (Dukes)
Rookie Year: 2012
We would actually be pushing in against the wall with our design some where in the range of 50-70 lbs
Unread 07-02-2016, 14:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
The rules specifically say that some elements of the tower are not load bearing. If you had a five pound contact force to keep alignment, that would probably be OK, but 50-70 pounds is likely to be a problem.
See particularly G12 (esp G12.c) and the blue box under scaling in section 3.1.
