Problem with the dashboard
Hey guys! I am having troubles with the java dashboard. When I open the dashboard its crushing. I don't know what is the problem, but I think it's something with the configuratin. Does anyone knows where is the location of the dashboard file? Or how can I fix that?
Re: Problem with the dashboard
You can find the executable jar file here: C:\Users\USER\wpilib\tools\SmartDashboard.jar If it's a problem with the configuration file and it doesn't have the right file path you can edit it here, so it runs on start up. C:\Users\Public\Documents\FRC\FRC DS Data Storage and edit the command line line so it uses the SmartDashboard.jar filepath above on startup. |
You may not find a more elegant solution, so I'd advise reinstalling so you can get back to work during build season ASAP. Good luck! |
You are not alone too, here's the forum I started earlier in build season. I really just ended up reinstalling.
http://www.chiefdelphi.com/forums/sh...d.php?t=142281 |
Thanks to everyone. I found the configuration file and I deleted it, and now the java SmartDashboard is working.
