Go to Post this has Bugs Bunny/Road Runner physics written all over it! - KenWittlief [more]
Unread 02-07-2016, 02:52 PM
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
Rookie Year: 2011
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Reset navX roll
Is there a way to zero the navx roll midgame?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 02-07-2016, 07:03 PM
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: Reset navX roll
Yaw (z axis rotation angle): yes
Roll and Pitch (x and y axis rotation angles): no
See this page for detailed description of these terms.
Roll/Pitch angle does not drift over time - can you please explain why you would like to reset it, and what you would reset it to?
Unread 02-07-2016, 09:28 PM
Dan Waxman Dan Waxman is offline
FRC #0263 (Aftershock)
Rookie Year: 2016
Dan Waxman is an unknown quantity at this point
Re: Reset navX roll
While I don't think it's supported by navx, you can get around and effectively reset. I would do this by having a reset method which reads the current roll and sets it to a variable (lets say lastResetRoll). Then just subtract lastResetRoll from the current roll whenever you access roll and you have an effectively "reset" roll.
Unread 02-07-2016, 10:41 PM
ArchdukeTim
Rookie Year: 2011
Re: Reset navX roll
Our readouts say differently. Not buy much, but about .05 degree a second. We are trying to tell if we are on the ramps of the obstacles. I know it isn't much but it also doesn't equal 0 when we are on the ground.
Unread 02-07-2016, 11:09 PM
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Reset navX roll
Since it's reported to you as a float, it will never exactly equal zero. Floating point numbers aren't exact, they are only approximations, so you can never use an == comparison on floats or doubles and expect it to work.
The NavX is performing a sensor fusion algorithm which combines accelerometer and gyro data. When the robot is not moving, the accelerometers will read a constant 1G vector due to gravity, and this vector can be used to trim the pitch/roll readings even with zero gyro movement so they are exact. While moving, the estimated pitch/roll reading can be used to subtract gravity and get vehicle accelerations from an accelerometer reading both gravity and vehicle accelerations.
The 'drift' you're seeing is probably the error in the gyros being slowly corrected by the accelerometers.
There's also the possibility that you aren't truly flat on the ground, since e.g. a 6wd drop center will have a few degrees of normal chassis rock.
Kettering Motorsports
Unread 02-07-2016, 11:12 PM
Rookie Year: 2016
Re: Reset navX roll
Here, try something like this.
