Hi All,
I've been working with some adafruit DotStar LED strands, driving them with the RIO's onboard SPI (using Java). I have them working, but to do so required I chunk the data to send into 128-byte sections, and call the spi.write() multiple times (once per section). This was done because the maximum return value I ever saw spi.write() give was 128.
I'm not horribly experienced with SPI - is this an implicit limitation of SPI in general? Or of the libraries and hardware we're using for FRC? Perhaps also I forgot to set up some buffer properly. Has anyone else seen this?
EDIT: Here's the code in question
DotStarsLEDStrip.java
