9" Diameter Wheels
We had originally designed our drive chassis to be fit with the Andy pneumatic wheels. We're now looking at these wheels on a drive train compared to the defenses and thinking that they're rather small. We have 6 8" diameter wheels from earlier this wheel, but would prefer to find even bigger wheels. Our design constraints dictate that the biggest we can go as of now if 9.75" diameter with a 2 inch width. Does anyone know where to buy wheels between 8.5-9.75" in diameter and that have a 2" width? We need 12 if that's possible.
Re: 9" Diameter Wheels
First off, have you tested the wheels? I assure you that if you designed to use 8" wheels, you should try them out. Our team is able to get over the defenses with 6" wheels. Secondly, if you swap wheels, you'll need to modify your Gearbox so you can keep a reasonable speed, so keep that in mind.
Our wheels our enclosed within the chassis so we're pretty sure were going to hit the rock wall and stop with the Andymark wheels. The gearbox can be fixed rather painlessly if need be.
You could look into a system like Wildstang in 2012 to raise the front end and get the wheels on the defenses if space and weight allow.
Unfortunately our sheet metal chassis is set in stone at this point. We also only have three inches of clearance currently between our bumpers and the floor.
Bumper or chassis? Read the bumper rules carefully, they must be within the bumper zone.
Sorry I meant Chassis, the bumpers will be 4 inches above the floor. Thought's on doing something like 1114's 2012 chassis design?
Our team has run into a similar issue, as the 8" wheels are surprisingly small. Once our chassis was done, we realized we couldn't get over the rock wall and moat, but by simply using flexible plastic "skid plates" on the front to reduce the angle of attack we were able to do everything as planned.
Yeah Lexan would work fine, we just used some random ABS I think and yes we could get over the rock wall with only 3" of clearance.
#11
Assuming you guys are comfortable making/modifying hubs, Harbor Freight has an option:
http://www.harborfreight.com/8-inch-...ire-47638.html They are listed at 8", but are closer to 8.5" IIRC. There's a few Harbor Freight locations around Philadelphia (Sharon Hill, Norristown, Northeast Philly) if you want to inspect them in person. |
#12
Unfortunately they have been wiped clean of their inventory it appears - and won't have them until end of February per the website. But we used them in 2012 and they provide nice customer service, suggest giving a call to them. |
