Multiple errors with WPILIB in Eclipse
Hello CD. I am having many build errors with trying to build any project. It seems to be something wrong with the std namespace and with some header files for threading. It first started out as some wpilib header files saying it's missing pthread.h, then after installing pthead-32 through MinGW I got quite a few std errors saying std does not name a type "so and so". It may have something to do with the tool chains being dumb or the libraries, since I used a new computer and installed Eclipse with the plug-ins and tool chains and then created a new example project and it still not working, leaves me to think it's frc's fault. I do not know.
I have tried: Reinstalling everything from scratch. Creating a default example robot project. Trying 3 different computers (one of them being a Linux os) one window 8.1,other one windows 10. Using a computer with WPILIB never installed before. Useing cygwin. Adding everything into the paths for includes and libraries manually. Messing with different tool chains and builders. Crying. Almost all fixes I can find through Google search. I am really at a stand still and can't deploy code because of no binaries being built. This has taken much of my time and I really need help. Thank you. Here is the error when building for cygwin: Code:
21:14:22 **** Incremental Build of configuration Debug for project Stronghold with onboard vision ****
Info: Configuration "Debug" uses tool-chain "Cygwin GCC" that is unsupported on this system, attempting to build anyway.
Info: Internal Builder is used for build
g++ "-IC:\\Users\\NerdsOfPrey/wpilib/cpp/current/include" -O0 -g3 -Wall -c -fmessage-length=0 -std=c++11 -o "src\\Commands\\WaterBridge.o" "..\\src\\Commands\\WaterBridge.cpp"
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_mutex.h:20:0,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/ErrorBase.h:13,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Commands/Command.h:11,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Commands/CommandGroup.h:11,
from ..\src\Commands\WaterBridge.h:16,
from ..\src\Commands\WaterBridge.cpp:13:
c:\mingw\include\pthread.h:320:8: error: redefinition of 'struct timespec'
struct timespec {
In file included from c:\mingw\include\time.h:53:0,
from c:\mingw\lib\gcc\mingw32\4.8.1\include\c++\ctime:42,
from c:\mingw\lib\gcc\mingw32\4.8.1\include\c++\chrono:41,
from c:\mingw\lib\gcc\mingw32\4.8.1\include\c++\mutex:39,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_mutex.h:11,
c:\mingw\include\parts\time.h:105:8: error: previous definition of 'struct timespec'
struct timespec
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/ErrorBase.h:13:0,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_mutex.h:49:59: error: cannot convert '<brace-enclosed initializer list>' to 'pthread_mutex_t' in initialization
{0, 0, 0, 0x20 | PTHREAD_MUTEX_RECURSIVE_NP, 0, {0}}};
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_mutex.h:79:30: error: cannot convert '<brace-enclosed initializer list>' to 'pthread_mutex_t' in initialization
{0, 0, 0, 0x20, 0, {0}}};
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/Semaphore.hpp:3:0,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/HAL.hpp:24,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/SPI.h:10,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/ADXL345_SPI.h:12,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/WPILib.h:16,
from ..\src\Commands\../Robot.h:15,
from ..\src\Commands\Unscoop.h:17,
from ..\src\Commands\WaterBridge.h:17,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:27:11: error: 'condition_variable' in namespace 'std' does not name a type
typedef std::condition_variable::native_handle_type native_handle_type;
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:63:3: error: 'cv_status' in namespace 'std' does not name a type
std::cv_status wait_until(Lock& _lock,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:87:3: error: 'cv_status' in namespace 'std' does not name a type
std::cv_status wait_for(Lock& lock, const std::chrono::duration<Rep, Period>& rtime) {
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:97:3: error: 'native_handle_type' does not name a type
native_handle_type native_handle() {
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:102:3: error: 'condition_variable' in namespace 'std' does not name a type
std::condition_variable m_cond;
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:103:19: error: 'mutex' is not a member of 'std'
std::shared_ptr<std::mutex> m_mutex;
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:103:29: error: template argument 1 is invalid
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h: In constructor 'priority_condition_variable::priority_condition_variable()':
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:29:60: error: 'mutex' is not a member of 'std'
priority_condition_variable() : m_mutex(std::make_shared<std::mutex>()) {}
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:29:72: error: no matching function for call to 'make_shared()'
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:29:72: note: candidate is:
In file included from c:\mingw\lib\gcc\mingw32\4.8.1\include\c++\memory:82:0,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Base.h:84,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/ErrorBase.h:10,
c:\mingw\lib\gcc\mingw32\4.8.1\include\c++\bits\shared_ptr.h:610:5: note: template<class _Tp, class ... _Args> std::shared_ptr<_Tp1> std::make_shared(_Args&& ...)
make_shared(_Args&&... __args)
c:\mingw\lib\gcc\mingw32\4.8.1\include\c++\bits\shared_ptr.h:610:5: note: template argument deduction/substitution failed:
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:29:72: error: template argument 1 is invalid
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h: In member function 'void priority_condition_variable::notify_one()':
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:36:21: error: 'mutex' is not a member of 'std'
std::lock_guard<std::mutex> lock(*m_mutex);
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:36:31: error: template argument 1 is invalid
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:36:37: error: invalid type in declaration before '(' token
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:36:39: error: invalid type argument of unary '*' (have 'int')
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:37:5: error: 'm_cond' was not declared in this scope
m_cond.notify_one();
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:36:33: warning: unused variable 'lock' [-Wunused-variable]
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h: In member function 'void priority_condition_variable::notify_all()':
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:41:21: error: 'mutex' is not a member of 'std'
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:41:31: error: template argument 1 is invalid
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:41:37: error: invalid type in declaration before '(' token
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:41:39: error: invalid type argument of unary '*' (have 'int')
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:42:5: error: 'm_cond' was not declared in this scope
m_cond.notify_all();
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:41:33: warning: unused variable 'lock' [-Wunused-variable]
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h: In member function 'void priority_condition_variable::wait(Lock&)':
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:47:21: error: 'mutex' is not a member of 'std'
std::shared_ptr<std::mutex> _mutex = m_mutex;
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:47:31: error: template argument 1 is invalid
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:47:40: error: invalid type in declaration before '=' token
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:48:22: error: 'mutex' is not a member of 'std'
std::unique_lock<std::mutex> my_lock(*_mutex);
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:48:32: error: template argument 1 is invalid
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:48:41: error: invalid type in declaration before '(' token
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:48:43: error: invalid type argument of unary '*' (have 'int')
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:53:22: error: 'mutex' is not a member of 'std'
std::unique_lock<std::mutex> my_lock2(std::move(my_lock));
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:53:32: error: template argument 1 is invalid
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:53:42: error: invalid type in declaration before '(' token
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:54:5: error: 'm_cond' was not declared in this scope
m_cond.wait(my_lock2);
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h: In member function 'bool priority_condition_variable::wait_until(Lock&, const std::chrono::time_point<_Clock, _Dur>&, Predicate)':
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:79:43: error: 'std::cv_status' has not been declared
if (wait_until(lock, atime) == std::cv_status::timeout) {
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/HAL.hpp:24:0,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/Semaphore.hpp: At global scope:
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/Semaphore.hpp:8:9: error: 'native_handle_type' in 'class priority_condition_variable' does not name a type
typedef priority_condition_variable::native_handle_type NATIVE_MULTIWAIT_ID;
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/HAL.hpp:25:0,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/Task.hpp:4:1: error: 'include' does not name a type
include <pthread.h>
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/WPILib.h:30:0,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/CameraServer.h:36:3: error: 'thread' in namespace 'std' does not name a type
std::thread m_serverThread;
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/CameraServer.h:37:3: error: 'thread' in namespace 'std' does not name a type
std::thread m_captureThread;
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/CameraServer.h:39:3: error: 'condition_variable_any' in namespace 'std' does not name a type
std::condition_variable_any m_newImageVariable;
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/CANJaguar.h:16:0,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/WPILib.h:31,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/cpp/Semaphore.hpp:28:3: error: 'condition_variable_any' in namespace 'std' does not name a type
std::condition_variable_any m_condition;
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Commands/Scheduler.h:14:0,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/LiveWindow/LiveWindow.h:13,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/PIDInterface.h:12,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/CANTalon.h:14,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/WPILib.h:32,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/networktables/NetworkTable.h:25:3: error: 'mutex' in namespace 'std' does not name a type
std::mutex m_mutex;
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/CANTalon.h:15:0,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/HAL/CanTalonSRX.h:268:3: error: 'mutex' in namespace 'std' does not name a type
std::mutex _mutMotProf;
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/DriverStation.h:12:0,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/WPILib.h:51,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Task.h:36:3: error: 'thread' in namespace 'std' does not name a type
std::thread::id get_id() const noexcept;
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Task.h:37:3: error: 'thread' in namespace 'std' does not name a type
std::thread::native_handle_type native_handle();
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Task.h:48:3: error: 'thread' in namespace 'std' does not name a type
std::thread m_thread;
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Task.h:53:0,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/DriverStation.h:12,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Task.inc: In constructor 'Task::Task(const string&, Function&&, Args&& ...)':
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Task.inc:25:3: error: 'm_thread' was not declared in this scope
m_thread = std::thread(std::forward<std::decay_t<Function>>(function),
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Task.inc:25:14: error: 'thread' is not a member of 'std'
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/WPILib.h:51:0,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/DriverStation.h: At global scope:
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/DriverStation.h:111:3: error: 'condition_variable_any' in namespace 'std' does not name a type
std::condition_variable_any m_waitForDataCond;
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/IterativeRobot.h:11:0,
from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/WPILib.h:61,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/RobotBase.h:53:30: error: 'FUNCPTR' has not been declared
static void startRobotTask(FUNCPTR factory);
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/RobotBase.h:54:25: error: 'FUNCPTR' has not been declared
static void robotTask(FUNCPTR factory, Task *task);
In file included from C:\Users\NerdsOfPrey/wpilib/cpp/current/include/WPILib.h:95:0,
C:\Users\NerdsOfPrey/wpilib/cpp/current/include/Vision/AxisCamera.h:94:3: error: 'thread' in namespace 'std' does not name a type
21:14:24 Build Finished (took 1s.996ms)
Code:
19:19:13 **** Incremental Build of configuration Debug for project Stronghold with onboard vision ****
g++ "-IC:\\Users\\Brandon/wpilib/cpp/current/include" -IC:/visionpls/_Includes/OpenCv/2.4.10 "-IC:\\Users\\Brandon\\Desktop\\Brandon C++ Projects/Stronghold With New RobotBuilder Code/src" -O0 -g3 -Wall -c -fmessage-length=0 -std=c++11 -o "src\\Commands\\AutonomousDriveForward.o" "..\\src\\Commands\\AutonomousDriveForward.cpp"
In file included from C:\Users\Brandon/wpilib/cpp/current/include/ErrorBase.h:13:0,
from C:\Users\Brandon/wpilib/cpp/current/include/Commands/Subsystem.h:11,
from ..\src\Commands\AutonomousDriveForward.h:16,
from ..\src\Commands\AutonomousDriveForward.cpp:12:
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_mutex.h:49:59: error: cannot convert '<brace-enclosed initializer list>' to 'pthread_mutex_t' in initialization
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_mutex.h:79:30: error: cannot convert '<brace-enclosed initializer list>' to 'pthread_mutex_t' in initialization
In file included from C:\Users\Brandon/wpilib/cpp/current/include/HAL/Semaphore.hpp:3:0,
from C:\Users\Brandon/wpilib/cpp/current/include/HAL/HAL.hpp:24,
from C:\Users\Brandon/wpilib/cpp/current/include/SPI.h:10,
from C:\Users\Brandon/wpilib/cpp/current/include/ADXL345_SPI.h:12,
from C:\Users\Brandon/wpilib/cpp/current/include/WPILib.h:16,
from ..\src\Commands\AutonomousDriveForward.h:17,
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:27:11: error: 'condition_variable' in namespace 'std' does not name a type
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:63:3: error: 'cv_status' in namespace 'std' does not name a type
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:87:3: error: 'cv_status' in namespace 'std' does not name a type
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:97:3: error: 'native_handle_type' does not name a type
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:102:3: error: 'condition_variable' in namespace 'std' does not name a type
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:103:19: error: 'mutex' is not a member of 'std'
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:103:29: error: template argument 1 is invalid
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h: In constructor 'priority_condition_variable::priority_condition_variable()':
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:29:60: error: 'mutex' is not a member of 'std'
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:29:72: error: no matching function for call to 'make_shared()'
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:29:72: note: candidate is:
from C:\Users\Brandon/wpilib/cpp/current/include/Base.h:84,
from C:\Users\Brandon/wpilib/cpp/current/include/ErrorBase.h:10,
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:29:72: error: template argument 1 is invalid
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h: In member function 'void priority_condition_variable::notify_one()':
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:36:21: error: 'mutex' is not a member of 'std'
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:36:31: error: template argument 1 is invalid
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:36:37: error: invalid type in declaration before '(' token
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:36:39: error: invalid type argument of unary '*' (have 'int')
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:37:5: error: 'm_cond' was not declared in this scope
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:36:33: warning: unused variable 'lock' [-Wunused-variable]
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h: In member function 'void priority_condition_variable::notify_all()':
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:41:21: error: 'mutex' is not a member of 'std'
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:41:31: error: template argument 1 is invalid
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:41:37: error: invalid type in declaration before '(' token
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:41:39: error: invalid type argument of unary '*' (have 'int')
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:42:5: error: 'm_cond' was not declared in this scope
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:41:33: warning: unused variable 'lock' [-Wunused-variable]
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h: In member function 'void priority_condition_variable::wait(Lock&)':
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:47:21: error: 'mutex' is not a member of 'std'
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:47:31: error: template argument 1 is invalid
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:47:40: error: invalid type in declaration before '=' token
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:48:22: error: 'mutex' is not a member of 'std'
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:48:32: error: template argument 1 is invalid
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:48:41: error: invalid type in declaration before '(' token
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:48:43: error: invalid type argument of unary '*' (have 'int')
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:53:22: error: 'mutex' is not a member of 'std'
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:53:32: error: template argument 1 is invalid
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:53:42: error: invalid type in declaration before '(' token
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:54:5: error: 'm_cond' was not declared in this scope
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h: In member function 'bool priority_condition_variable::wait_until(Lock&, const std::chrono::time_point<_Clock, _Dur>&, Predicate)':
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/priority_condition_variable.h:79:43: error: 'std::cv_status' has not been declared
In file included from C:\Users\Brandon/wpilib/cpp/current/include/HAL/HAL.hpp:24:0,
C:\Users\Brandon/wpilib/cpp/current/include/HAL/Semaphore.hpp: At global scope:
C:\Users\Brandon/wpilib/cpp/current/include/HAL/Semaphore.hpp:8:9: error: 'native_handle_type' in 'class priority_condition_variable' does not name a type
In file included from C:\Users\Brandon/wpilib/cpp/current/include/WPILib.h:30:0,
C:\Users\Brandon/wpilib/cpp/current/include/CameraServer.h:36:3: error: 'thread' in namespace 'std' does not name a type
C:\Users\Brandon/wpilib/cpp/current/include/CameraServer.h:37:3: error: 'thread' in namespace 'std' does not name a type
C:\Users\Brandon/wpilib/cpp/current/include/CameraServer.h:39:3: error: 'condition_variable_any' in namespace 'std' does not name a type
In file included from C:\Users\Brandon/wpilib/cpp/current/include/CANJaguar.h:16:0,
from C:\Users\Brandon/wpilib/cpp/current/include/WPILib.h:31,
C:\Users\Brandon/wpilib/cpp/current/include/HAL/cpp/Semaphore.hpp:28:3: error: 'condition_variable_any' in namespace 'std' does not name a type
In file included from C:\Users\Brandon/wpilib/cpp/current/include/Commands/Scheduler.h:14:0,
from C:\Users\Brandon/wpilib/cpp/current/include/LiveWindow/LiveWindow.h:13,
from C:\Users\Brandon/wpilib/cpp/current/include/PIDInterface.h:12,
from C:\Users\Brandon/wpilib/cpp/current/include/CANTalon.h:14,
from C:\Users\Brandon/wpilib/cpp/current/include/WPILib.h:32,
C:\Users\Brandon/wpilib/cpp/current/include/networktables/NetworkTable.h:25:3: error: 'mutex' in namespace 'std' does not name a type
std::mutex m_mutex;
In file included from C:\Users\Brandon/wpilib/cpp/current/include/CANTalon.h:15:0,
C:\Users\Brandon/wpilib/cpp/current/include/HAL/CanTalonSRX.h:268:3: error: 'mutex' in namespace 'std' does not name a type
In file included from C:\Users\Brandon/wpilib/cpp/current/include/DriverStation.h:12:0,
from C:\Users\Brandon/wpilib/cpp/current/include/WPILib.h:51,
C:\Users\Brandon/wpilib/cpp/current/include/Task.h:36:3: error: 'thread' in namespace 'std' does not name a type
C:\Users\Brandon/wpilib/cpp/current/include/Task.h:37:3: error: 'thread' in namespace 'std' does not name a type
C:\Users\Brandon/wpilib/cpp/current/include/Task.h:48:3: error: 'thread' in namespace 'std' does not name a type
In file included from C:\Users\Brandon/wpilib/cpp/current/include/Task.h:53:0,
from C:\Users\Brandon/wpilib/cpp/current/include/DriverStation.h:12,
C:\Users\Brandon/wpilib/cpp/current/include/Task.inc: In constructor 'Task::Task(const string&, Function&&, Args&& ...)':
C:\Users\Brandon/wpilib/cpp/current/include/Task.inc:25:3: error: 'm_thread' was not declared in this scope
C:\Users\Brandon/wpilib/cpp/current/include/Task.inc:25:14: error: 'thread' is not a member of 'std'
In file included from C:\Users\Brandon/wpilib/cpp/current/include/WPILib.h:51:0,
C:\Users\Brandon/wpilib/cpp/current/include/DriverStation.h: At global scope:
C:\Users\Brandon/wpilib/cpp/current/include/DriverStation.h:111:3: error: 'condition_variable_any' in namespace 'std' does not name a type
In file included from C:\Users\Brandon/wpilib/cpp/current/include/WPILib.h:95:0,
C:\Users\Brandon/wpilib/cpp/current/include/Vision/AxisCamera.h:94:3: error: 'thread' in namespace 'std' does not name a type
19:19:19 Build Finished (took 5s.715ms)
Re: Multiple errors with WPILIB in Eclipse
You should not be using cygwin or mingw. You should be using the FRC specific toolchain (Installing the C++ Toolchains here: http://wpilib.screenstepslive.com/s/...eclipse-c-java)
Ok, post the complete error log from the correct compiler then. These two error logs from the wrong compilers are not helpful.
How do I use the compiler then? Those were the errors I get when I use the cross compiler with the cdt internal builder. I also got these same errors using it one a computer with Mingw or cyagwin never installed.
We are having the same issues - C++ code that runs perfectly on 2015 in Eclipse throws multiple errors on the 2016 Eclipse. We have reinstalled with no help and are stuck with competition next week. Any help greatly appreciated!
It looks like Mingw includes are interfering with toolchain includes.
You need to remove Mingw and Cygwin from your build computers. It also looks like the toolchain compilers are not being called. Create a new "example wpilib project" in Eclipse and see if that builds. If it does, you'll need to create a new "wpilib robot project" and copy all of your code into that. |
