Go to Post Different approaches to the same problem. Isn't it better to focus on understanding both than to be dogmatic about it? - Greg McKaskle [more]
Unread 08-02-2016, 22:08
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
Rookie Year: 2013
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Versa planetary lock up
We are using versa planetaries for the first time this year, and one of the ones on our shooter has pretty much locked up. Took everything apart, no visible damage when looking quick. Reassemble and when spinning he output shaft by hand can feel a hard spot.
To make matters worse the 3:1 s are out of stock.
Which brings me to my next question any teams have 2 or 3 they can part with? Obviously we would pay for the parts and any shipping
Unread 08-02-2016, 22:16
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Versa planetary lock up
Do you remember what happened before it locked up?
We have a couple extras, but we're in Canada. If you're really out of luck PM me and we'll figure it out.
All opinions are my own.
Unread 08-02-2016, 22:32
dradel's Avatar
Rookie Year: 2013
We were taking a couple test shots with the shooter and thought we heard a noise, but weren't sure. The shooter worked after said noise, this was Saturday, this evening wanted to check how it would work with intake, and when we applied power to the motor to check rotation it made a small spark but shaft didn't turn.
Unread 08-02-2016, 22:40
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Do you have pictures and/or a detailed description of what you've tried? The people of CD may be able to fix your gearbox, if only there is more information.
Unread 08-02-2016, 22:52
dradel's Avatar
Rookie Year: 2013
No pics as there is nothing to really see. Disassembled, looked quick for damage, regreased, reassemble. Spin output shaft by hand, has a stiff spot. Take back apart try different ring gear, same result so telling me an issue with the sun, or one of the planets
Unread 08-02-2016, 23:30
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
Rookie Year: 2011
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Spark?
Did you verify the motor is working correctly stand alone?
Does the gearbox rotate smoothly with out the motor?
Depending on how you were using the gearbox on your shooter, it could of damaged a bearing in it.
Does your shooter directly drive the wheel?
Some pictures of the shooter type, or description can help.
Things to list could be...
Shooter type .. Flywheel , two wheel, (benchtop grinder)
Motor Type .. CIM, BAG ...etc.
Ratio, which I believe you stated as 3:1
How power is applied to motor.. talon, victor... etc.
Only option if you wish to continue troubleshooting is with the other gearbox.
Move the gear set or ring gear form one to the other. One thing at a time and see what makes a difference in hand turning the shaft.
Then you discover which part fixes it. Then compare the parts and see what happened.
Many times when hand turning and you hit a specific snag in the rotation. Verify location by going both directions. Many times some debris is in one of the teeth. A large amount of rotations before snagging is something in the ring gear. A short amount of turn usually is in the sun or planet gears.
I have used these gearboxes in many various ways and some of time we were rough on them. They tend to hold up very well, but not bulletproof.
Good luck with this, I have many parts to those gearboxs and would gladly send them. Though I am one of the further points to offer so far.
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Division TBD | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 08-02-2016, 23:39
TikiTech's Avatar
Mr. H
Rookie Year: 2011
Still need to try the gear set in old ring gear.
Though this is starting to sound like either the output shaft is bent / damaged or the bearings.
Still need to try to hand turn without the motor. Just take off the plate & motor assembly.
Or perhaps the motor adapter set pin is hitting something inside.
A quick look inside?
You might have to devote some time to doing this.
Did you clean the teeth on the ring gear before you reassembled?
What are you greasing with?
A piece of chipped gear stuck between teeth can be quite small.
When the output shaft assembly is removed does it turn freely?
Unread 09-02-2016, 00:15
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
Dradel,
Have you inspected the gear teeth? Do all of the planets spin freely on the carrier plate pins? Are all of the carrier pins still fully pressed into the carrier plate?
As always, feel free to email me at the address in my signature and I"ll help you sort out any issues.
-Aren
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 09-02-2016, 07:17
dradel's Avatar
Rookie Year: 2013
At tiki, the spark was due to the gear box being stuck, and we were sending power with jumper wires with clips directly to a battery. So the stuck box was causing a bunch of current at the motor.
We did have the motor (775 pro) off the box when we were looking for the issue. I didn't check for bad bearing or bent shaft but will this evening.
At Aren I sent an email to vex about this email address is same as my name here. My contact info is included in email perhaps you could give me a call?
Unread 09-02-2016, 07:46
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We had some issues with the 775pro and VP randomly loosening up and loosing friction (The gearbox would spin and the motor would stop).
It had something to do with the set screw.
We decided after awhile that it wasn't worth using a atm out of stock motor, and an out of stock gearbox so we switched over to a 1:1 mini cim setup. Kind of sad but there was really no other good choice.
I have no clue what the issue was but it happened on both setups. Originally I thought it was bad assembly but after further inspection it was not.
Unread 09-02-2016, 07:58
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
Rookie Year: 2012
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
We had some smiler problems with the 3:1 gearboxes this year also. they never fully locked up but after about 3 hours of running the pins that hold the pinion gears started to work their way loose. we caught it but i imagine if we had let it go the box would have locked. I would take a look at those pins and make sure that the tops of them are a little below the top of the pinion gear.
FRC Rebound Rumble | Ultimate Ascent | Aerial Assist | Recycle Rush | FIRST Stronghold | FIRST STEAMWORKS
FLL Senior Solutions | Nature's Fury | Trash Treck | Animal Allies
Unread 09-02-2016, 09:04
dradel's Avatar
Rookie Year: 2013
When I had it apart yesterday I didn't notice the pins sticking higher than the small planet gears.
Oh and it was asked earlier what type of grease.... White lithium grease per vex website
Unread 09-02-2016, 12:21
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Mentor
FRC #2851 (Crevolution)
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
Planets don't normally skip when a tooth fails like in a spur gear trans. Planetarys will eat themselves quickly.
I'd put money on Sperkowsky being on the right path.
I'd suggest using a dab of locktight on the set screw to make sure its secured. We had run into a similar issue when mounting bag motors to the versaplanitary transmissions.
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
Unread 09-02-2016, 12:47
dradel's Avatar
Rookie Year: 2013
If you are referring to the set screw that goes into the input coupler it was loctited as we assembled the gearboxes initially. When we disassembled last night the old loctite was cleaned off the set screw and from the hole in the coupler and more loctite was applied.
