Go to Post Come on, Dave! We need more lyrics! (I'll bring you fresh KK doughnuts at VCU's regional! :D ) - Squirrelrock [more]
Unread 09-02-2016, 16:26
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
Compiling GRIP for the Jetson TK1
Our team wants to use the TK1 to do image processing and to exeriment
with GRIP tools on it.
Here's what I did to compile and run GRIP on the Jetson TK1.
1. [ flash and install the NVidia distribution ]
2. Mark the special NVidia package so that updates won't overwrite them.
Code:
sudo apt-mark hold xserver-xorg-core
3. install oracle java jdk8
Code:
http://www.oracle.com/technetwork/java/javase/downloads/jdk8-downloads-2133151.html
jdk-8u65-linux-arm32-vfp-hflt.tar.gz
I installed it in /usr/lib/jvm/
$ export JAVA_HOME=/usr/lib/jvm/jdk1.8.0_65
$ PATH=$PATH:$JAVA_HOME/bin
3. build ntcore
Code:
git clone --depth=1 https://github.com/PeterJohnson/ntcore.git
./gradlew :arm:build -PcompilerPrefix=
# ./gradlew publish -PmakeDesktop  ??
$ ./gradlew -PcompilerPrefix= -PmakeDesktop :arm:build
4. build openjfx
Code:
https://wiki.openjdk.java.net/displa...ilding+OpenJFX
install deps
sudo apt-get install bison flex gperf libasound2-dev libgl1-mesa-dev \
    libgstreamer0.10-dev libgstreamer-plugins-base0.10-dev libjpeg-dev \
    libpng-dev libx11-dev libxml2-dev libxslt1-dev libxt-dev \
    libxxf86vm-dev pkg-config x11proto-core-dev \
    x11proto-xf86vidmode-dev  libgtk2.0-dev \
    libxtst-dev libudev-dev
edit /etc/apt/sources.list
    and uncomment universe sources
sudo apt-get update
sudo apt-get install mercurial libavcodec-dev libavformat-dev
install gradle
    wget https://services.gradle.org/distribu...le-1.8-bin.zip
Apply Diffs
Code:
diff --git a/build.gradle b/build.gradle
index c1d2486..843d99a 100644
--- a/build.gradle
+++ b/build.gradle
@@ -704,7 +704,7 @@ if (IS_WINDOWS && OS_ARCH != "x86" && OS_ARCH != "amd64") {
     throw new Exception("Unknown and unsupported build architecture: $OS_ARCH")
 } else if (IS_MAC && OS_ARCH != "x86_64") {
-} else if (IS_LINUX && OS_ARCH != "i386" && OS_ARCH != "amd64") {
+} else if (IS_LINUX && OS_ARCH != "i386" && OS_ARCH != "amd64" && OS_ARCH != "arm") {
@@ -2554,8 +2554,8 @@ project(":web") {
                     } else {
                         environment([
                             "QMAKESPEC"      : "linux-g++-32",
-                            "QMAKE_CFLAGS"   : "-m32",
-                            "QMAKE_LFLAGS"   : "-m32",
+                            // "QMAKE_CFLAGS"   : "-m32",
+                            // "QMAKE_LFLAGS"   : "-m32",
                 } else if (t.name.startsWith("arm")) {
@@ -3260,8 +3260,8 @@ project(":apps") {
               ant.properties['jfxbuild.jfxrt.jar'] = jfxrtJar
               ant.properties['platforms.JDK_1.8.home'] = "${rootProject.ext.JDK_HOME}"
-              ant.project.executeTarget("sampleAppsJar")
-              ant.project.executeTarget("scenebuilderSampleAppsJar")
+              // ant.project.executeTarget("sampleAppsJar")
+              // ant.project.executeTarget("scenebuilderSampleAppsJar")
               if (!t.name.startsWith("arm")) {
                 ant.project.executeTarget("scenebuilderAppJar")
diff --git a/buildSrc/linux.gradle b/buildSrc/linux.gradle
index 753d79c..34a313f 100644
--- a/buildSrc/linux.gradle
+++ b/buildSrc/linux.gradle
@@ -45,7 +45,7 @@ def commonFlags = [
         "-fno-strict-aliasing"
    "-fPIC", "-fno-omit-frame-pointer", // optimization flags
         "-W"
    "-Wall", "-Wno-unused", "-Wno-parentheses", "-Werror=implicit-function-declaration"] // warning f
-if (!IS_64) {
+if (false && !IS_64) {
     commonFlags += "-m32"
@@ -173,7 +173,7 @@ LINUX.launcher.compiler = compiler
 LINUX.launcher.ccFlags = ["-DJAVAARCH=\"$OS_ARCH\""
    "-I$JDK_HOME/include", "-I$JDK_HOME/include/linux", "-c"]
 LINUX.launcher.linker = linker
 LINUX.launcher.linkFlags = ["-ldl"]
-if (!IS_64) {
     LINUX.launcher.ccFlags += "-m32"
     LINUX.launcher.linkFlags += "-m32"
@@ -183,7 +183,7 @@ LINUX.launcherlibrary.compiler = compiler
 LINUX.launcherlibrary.ccFlags = ["-DJAVAARCH=\"$OS_ARCH\""
 LINUX.launcherlibrary.linker = linker
 LINUX.launcherlibrary.linkFlags = ["-ldl"
    "-lpthread", "-shared"]
-if (!IS_64) {
     LINUX.launcherlibrary.ccFlags += "-m32"
     LINUX.launcherlibrary.linkFlags += "-m32"
Build javafx
Code:
gradle
Test javafx
Code:
gradle test
Package
Code:
gradle zips
Code:
Extract jar over the existing jdk
build/bundles/javafx-sdk-overlay.zip contains data to overlay existing JAVA_HOME
Code:
cd /usr/lib/jvm/jdk1.8.0_65
jar -xvf [...]/build/bundles/javafx-sdk-overlay.zip
5. install NVIDIA opencv
These packages are from the NVidia TK1 download page.
Code:
    sudo dpkg -i cuda-repo-l4t-r23.1-7-0-local_7.0-71_armhf.deb
    sudo dpkg -i libopencv4tegra-repo_2.4.12.3_armhf_l4t-r23.deb
    sudo apt-get update
    sudo apt-get install cuda-toolkit-7-0 libopencv4tegra libopencv4tegra-dev
6. install maven
[ install pseudo packages java8 dev packages ]
create file java8-jre
Code:
### Commented entries have reasonable defaults.
### Uncomment to edit them.
# Source: <source package name; defaults to package name>
Section: java
Priority: optional
# Homepage: <enter URL here; no default>
Standards-Version: 3.9.2
Package: java8-jre
Version: 1.8
# Maintainer: Your Name <yourname@example.com>
# Pre-Depends: <comma-separated list of packages>
Depends: java8-jre-headless
# Recommends: <comma-separated list of packages>
# Suggests: <comma-separated list of packages>
Provides: java-runtime, java2-runtime, java5-runtime, java6-runtime, java7-runtime
# Replaces: <comma-separated list of packages>
# Architecture: all
# Copyright: <copyright file; defaults to GPL2>
# Changelog: <changelog file; defaults to a generic changelog>
# Readme: <README.Debian file; defaults to a generic one>
# Extra-Files: <comma-separated list of additional files for the doc directory>
# Files: <pair of space-separated paths; First is file to include, second is destination>
#  <more pairs, if there's more than one file to include. Notice the starting space>
Description: java 8
 oracle java 8
 From Java Oracle
create file java8-jre-headless
Code:
Section: java
Priority: optional
Package: java8-jre
Version: 1.8
Provides: java-runtime-headless, java2-runtime-headless, java5-runtime-headless, java6-runtime-headless, java7-runtime-headless, openjdk-7-jre-zero
# Architecture: all
Description: java 8 headless
 oracle java 8 headless
 From Java Oracle support
create and install java deb files
Code:
sudo apt-get install equivs
equivs-build java8-jre
equivs-build java8-jre-headless
sudo dpkg -i java8-jre*.deb
sudo apt-get update
sudo apt-get install maven
7. install and build org.bytedeco.javacpp
Code:
git clone --depth=1 https://github.com/bytedeco/javacpp.git
edit src/main/resources/org/bytedeco/javacpp/properties/linux-arm.properties
Code:
diff --git a/src/main/resources/org/bytedeco/javacpp/properties/linux-arm.properties b/src/main/resources/org/by
index 6580495..fcd0c1c 100644
--- a/src/main/resources/org/bytedeco/javacpp/properties/linux-arm.properties
+++ b/src/main/resources/org/bytedeco/javacpp/properties/linux-arm.properties
@@ -5,8 +5,8 @@ platform.includepath.prefix=-I
 platform.includepath=
 platform.compiler=g++
 platform.compiler.cpp11=-std=c++11
-platform.compiler.default=-march=armv5te
-platform.compiler.fastfpu=-march=armv7-a -mfpu=neon -ffast-math
+platform.compiler.default=-march=native
+platform.compiler.fastfpu=-march=armv7-a -mfpu=neon-vfpv4 -ffast-math
 platform.compiler.nodeprecated=-Wno-deprecated-declarations
 platform.compiler.output=-Wl,-rpath,$ORIGIN/ -Wall -O3 -fPIC -shared -s -o\u0020
 platform.linkpath.prefix=-L
Build
Code:
mvn install
8. install and build org.bytedeco.javacpp-presets
install deps curl cmake
Code:
sudo apt-get install curl cmake
apply patches
Code:
diff --git a/opencv/cppbuild.sh b/opencv/cppbuild.sh
index 25a9b50..363a171 100755
--- a/opencv/cppbuild.sh
+++ b/opencv/cppbuild.sh
@@ -47,7 +47,7 @@ case $PLATFORM in
         make install/strip
     linux-arm)
-        CC=arm-linux-gnueabi-"$OLDCC" CXX=arm-linux-gnueabi-"$OLDCXX" CMAKE_C_COMPILER=$CC CMAKE_CXX_COMPILER=$
+        CC="$OLDCC" CXX="$OLDCXX" CMAKE_C_COMPILER=$CC CMAKE_CXX_COMPILER=$CXX $CMAKE -DCMAKE_INSTALL_PREFIX=..
         make -j4
         make install
diff --git a/artoolkitplus/cppbuild.sh b/artoolkitplus/cppbuild.sh
index a487aae..a0be80f 100755
--- a/artoolkitplus/cppbuild.sh
+++ b/artoolkitplus/cppbuild.sh
@@ -27,6 +27,11 @@ case $PLATFORM in
         make -j4
         make install
+    linux-arm)
+        CC="$OLDCC" CXX="$OLDCXX" $CMAKE -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=..
+        make -j4
+        make install
     linux-x86)
         CC="$OLDCC -m32" CXX="$OLDCXX -m32" $CMAKE -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=..
         make -j4
diff --git a/ffmpeg/cppbuild.sh b/ffmpeg/cppbuild.sh
index b8ebb10..8c8e617 100644
--- a/ffmpeg/cppbuild.sh
+++ b/ffmpeg/cppbuild.sh
@@ -28,7 +28,7 @@ else
     LAME=lame-3.99.5
     SPEEX=speex-1.2rc2
     OPENCORE_AMR=opencore-amr-0.1.3
-    OPENSSL=openssl-1.0.2e
+    OPENSSL=openssl-1.0.2f
     OPENH264_VERSION=1.5.0
     X265=x265_1.8
     VPX_VERSION=v1.5.0
@@ -166,6 +166,44 @@ case $PLATFORM in
         make install
+    linux-arm)         ## host native build
+        cd $LAME
+        ./configure --prefix=$INSTALL_PATH --disable-shared --with-pic CFLAGS=""
+        make -j $MAKEJ
+        make install
+        cd ../$SPEEX
+        make -j $MAKEJ
+        make install
+        cd ../$OPENCORE_AMR
+        ./configure --prefix=$INSTALL_PATH --disable-shared --with-pic CFLAGS="" CXXFLAGS=""
+        make -j $MAKEJ
+        make install
+        cd ../$OPENSSL
+        ./Configure linux-armv4 -march=armv7-a -D__ARM_MAX_ARCH__=8 -fPIC no-shared --prefix=$INSTALL_PATH
+        make # fails with -j > 1
+        make install
+        cd ../openh264-$OPENH264_VERSION
+        make -j $MAKEJ DESTDIR=./ PREFIX=.. AR=ar ARCH=arm libraries install-static
+        cd ../$X264
+        ./configure --prefix=$INSTALL_PATH --enable-static --enable-pic --disable-opencl
+        make -j $MAKEJ
+        make install
+        cd ../$X265
+        CC="gcc" CXX="g++" $CMAKE -DENABLE_SHARED=OFF -DENABLE_PIC=ON -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTAL
+        make -j $MAKEJ
+        make install
     linux-x86)
         cd $LAME
         ./configure --prefix=$INSTALL_PATH --disable-shared --with-pic --host=i686-linux CFLAGS="-m32 -msse2"
diff --git a/flandmark/cppbuild.sh b/flandmark/cppbuild.sh
index 3f32ef7..d0fd1cd 100755
--- a/flandmark/cppbuild.sh
+++ b/flandmark/cppbuild.sh
@@ -32,6 +32,12 @@ case $PLATFORM in
         cp libflandmark/*.h ../include
         cp libflandmark/*.a ../lib
+    linux-arm)
+        CC="$OLDCC" CXX="$OLDCXX" $CMAKE -DCMAKE_BUILD_TYPE=Release -DOpenCV_DIR=$OPENCV_PATH/share/OpenCV/
+        make -j4 flandmark_static
+        cp libflandmark/*.h ../include
+        cp libflandmark/*.a ../lib
     linux-x86)
         CC="$OLDCC -m32" CXX="$OLDCXX -m32" $CMAKE -DCMAKE_BUILD_TYPE=Release -DOpenCV_DIR=$OPENCV_PATH/share/O
diff --git a/libdc1394/cppbuild.sh b/libdc1394/cppbuild.sh
index c63118d..2e39444 100755
--- a/libdc1394/cppbuild.sh
+++ b/libdc1394/cppbuild.sh
@@ -17,6 +17,11 @@ tar -xzvf ../libdc1394-$LIBDC1394_VERSION.tar.gz
 cd libdc1394-$LIBDC1394_VERSION
 case $PLATFORM in
+    linux-arm)
+        CC="$OLDCC" ./configure --prefix=$INSTALL_PATH
+        make -j4
+        make install-strip
     linux-x86)
         CC="$OLDCC -m32" ./configure --prefix=$INSTALL_PATH
         make -j4
diff --git a/libfreenect/cppbuild.sh b/libfreenect/cppbuild.sh
index 57bbf90..2aeb7aa 100755
--- a/libfreenect/cppbuild.sh
+++ b/libfreenect/cppbuild.sh
@@ -27,6 +27,11 @@ fi
 cd libfreenect-$LIBFREENECT_VERSION
 case $PLATFORM in
+    linux-arm)
+        CC="$OLDCC" CXX="$OLDCXX" $CMAKE -DCMAKE_BUILD_TYPE=Release -DBUILD_EXAMPLES=OFF -DBUILD_FAKENECT=OFF -
+        make -j4
+        make install
     linux-x86)
         CC="$OLDCC -m32" CXX="$OLDCXX -m32" $CMAKE -DCMAKE_BUILD_TYPE=Release -DBUILD_EXAMPLES=OFF -DBUILD_FAKE
         make -j4
Code:
# -march=native??  -mtune=cortex-a15 -march=armv7-a -mfpu=neon-vfpv4
mvn -Dplatform.compiler.default="" install --projects .,opencv,videoinput,ffmpeg,flycapture,libdc1394,libfreenect,artoolkitplus,flandmark
ln ~/.m2/repository/org/bytedeco/javacpp-presets/opencv/3.1.0-1.2-SNAPSHOT/opencv-3.1.0-1.2-SNAPSHOT-linux-arm.jar ~/.m2/repository/org/bytedeco/javacpp-presets/opencv/3.1.0-1.2-SNAPSHOT/opencv-3.1.0-1.2-SNAPSHOT-linux-arm_32.jar
ln ~/.m2/repository/org/bytedeco/javacpp-presets/videoinput/0.200-1.2-SNAPSHOT/videoinput-0.200-1.2-SNAPSHOT-linux-arm.jar ~/.m2/repository/org/bytedeco/javacpp-presets/videoinput/0.200-1.2-SNAPSHOT/videoinput-0.200-1.2-SNAPSHOT-linux-arm_32.jar
9. install and build jogl
Code:
export TARGET_PLATFORM_ROOT=/
mkdir jogamp
cd jogamp
git clone --recursive --depth=1 https://github.com/sgothel/gluegen.git
git clone --recursive --depth=1 https://github.com/sgothel/jogl.git
build gluegen
Code:
cd gluegen
The default jogamp build is built from a cross compiler which has a different library layout than the native filesystem. We need to remove nonstdlib option from gcc compiles.
for: https://jogamp.org/bugzilla/show_bug.cgi?id=1190
Apply patch
Code:
diff --git a/make/gluegen-cpptasks-base.xml b/make/gluegen-cpptasks-base.xml
index 01d6146..766022c 100755
--- a/make/gluegen-cpptasks-base.xml
+++ b/make/gluegen-cpptasks-base.xml
@@ -1239,7 +1239,6 @@
          for official JogAmp builds! -->
     <linker id="linker.cfg.linux.armv6" name="${gcc.compat.compiler}">
       <linkerarg value="-fpic" />
-      <linkerarg value="-nostdlib" />
       <linkerarg value="-Bdynamic" />
       <linkerarg value="-static-libgcc" if="isGCC"/>
       <linkerarg value="-static-libstdc++" if="isGCC"/>
diff --git a/make/build.xml b/make/build.xml
index d7abcd8..c69b578 100644
--- a/make/build.xml
+++ b/make/build.xml
@@ -1221,7 +1221,7 @@
             <param name="description" value="GlueGen - JNI Glue Code Generator"/>
         </antcall>
         <antcall target="maven.${mvn.task}.artifact" inheritall="true">
-            <param name="artifactId" value="gluegen-rt"/>
+            <param name="artifactId" value="gluegen-rt-main"/>
             <param name="description" value="GlueGen runtime"/>
         </antcall>
         <antcall target="maven.${mvn.task}.native.artifact" inheritall="true">
Code:
cd make
ant
ant maven.install
build jogl
Code:
cd ../../jogl/make
ant
> from:
> https://gist.github.com/tysonmalchow/1624599
Code:
mvn install:install-file -Dversion=$VERSION -DlocalRepositoryPath="$MVN_REPO" -DgroupId=com.jogamp.jogl -DartifactId=jogl-all -Dpackaging=jar -Dfile="$TEMPFILE/jogl.all.jar" -DgeneratePom=true
mvn install:install-file -DlocalRepositoryPath="$MVN_REPO" -Dclassifier="$platform" -Dversion=$VERSION -DgroupId=com.jogamp.jogl -DartifactId=jogl-natives -Dpackaging=jar -Dfile="$TEMPFILE/jogl-all-natives-$platform.jar" -DgeneratePom=true
Code:
cd ../build
mvn install:install-file -Dversion=2.4 -DlocalRepository=~/.m2/repository -DgroupId=org.jogamp.jogl -DartifactId=jogl-all-main -Dpackaging=jar -Dfile="$PWD/jar/*" -DgeneratePom=true
mvn install:install-file -DlocalRepositoryPath=~/.m2/repository -Dclassifier="arm" -Dversion=2.4 -DgroupId=org.jogamp.jogl -DartifactId=jogl-natives -Dpackaging=jar -Dfile="$PWD/lib/*" -DgeneratePom=true
cp gluegen-rt.jar /home/ubuntu/.m2/repository/org/jogamp/gluegen/gluegen-rt-main/2.4/gluegen-rt-main-2.4.jar
cp jocl.jar /home/ubuntu/.m2/repository/org/jogamp/jocl/jocl-main/2.4/jocl-main-2.4.jar
cp jogl-all.jar /home/ubuntu/.m2/repository/org/jogamp/jogl/jogl-all-main/2.4/jogl-all-main-2.4.jar
build jocl
Code:
cd ../../jocl
Need to apply the following patch because of this error:
/home/ubuntu/src/jogamp/jocl/src/com/jogamp/opencl/llb/impl/CLDynamicLibraryBundleInfo.java:44:
error: CLDynamicLibraryBundleInfo is not abstract and does not override abstract method
searchToolLibSystemPathFirst() in DynamicLibraryBundleInfo
apply patch
Code:
diff --git a/src/com/jogamp/opencl/llb/impl/CLDynamicLibraryBundleInfo.java b/src/com/jogamp/opencl/llb/impl/CLD
index 4f3e682..9ac026b 100644
--- a/src/com/jogamp/opencl/llb/impl/CLDynamicLibraryBundleInfo.java
+++ b/src/com/jogamp/opencl/llb/impl/CLDynamicLibraryBundleInfo.java
@@ -157,6 +157,16 @@ public final class CLDynamicLibraryBundleInfo implements DynamicLibraryBundleInf
     public final RunnableExecutor getLibLoaderExecutor() {
         return DynamicLibraryBundle.getDefaultRunnableExecutor();
+    @Override
+    public final boolean searchToolLibInSystemPath() {
+       return true;
+    @Override
+    public final boolean searchToolLibSystemPathFirst() {
+       return true;
Code:
cd ../build
mvn install:install-file -Dversion=2.4 -DlocalRepository=~/.m2/repository -DgroupId=org.jogamp.jocl -DartifactId=jocl-main -Dpackaging=jar -Dfile="$PWD/jar/*" -DgeneratePom=true
10. install and build org.bytedeco.javacv
Code:
git clone --depth=1 https://github.com/bytedeco/javacv.git
apply patch
Code:
diff --git a/pom.xml b/pom.xml
index 00e10f0..792e503 100644
--- a/pom.xml
+++ b/pom.xml
@@ -92,7 +92,7 @@
     <dependency>
       <groupId>org.bytedeco.javacpp-presets</groupId>
       <artifactId>ffmpeg</artifactId>
-      <version>2.8.4-${javacpp.version}</version>
+      <version>2.8.5-${javacpp.version}</version>
     </dependency>
     <dependency>
@@ -141,19 +141,19 @@
     <dependency>
       <groupId>org.jogamp.gluegen</groupId>
       <artifactId>gluegen-rt-main</artifactId>
-      <version>2.3.1</version>
+      <version>2.4</version>
       <optional>true</optional>
     </dependency>
     <dependency>
       <groupId>org.jogamp.jogl</groupId>
       <artifactId>jogl-all-main</artifactId>
     </dependency>
     <dependency>
       <groupId>org.jogamp.jocl</groupId>
       <artifactId>jocl-main</artifactId>
     </dependency>
Code:
mvn -Pmarkers,ffmpeg,dc1394,flycapture,openkinect,videoinput,jogamp install
11. build GRIP
apply patch
Code:
index 01b152a..f485f7d 100644
--- a/build.gradle
+++ b/build.gradle
@@ -115,6 +115,9 @@ project(":core") {
     repositories {
         flatDir {
             dirs 'libs'
+            maven  {
+               url="file:///home/ubuntu/.m2/repository"
             maven {
                 url = "http://first.wpi.edu/FRC/roborio/maven/development"
@@ -122,11 +125,11 @@ project(":core") {
     dependencies {
-        compile group: 'org.bytedeco', name: 'javacv', version: '1.1'
-        compile group: 'org.bytedeco.javacpp-presets', name: 'opencv', version: '3.0.0-1.1'
-        compile group: 'org.bytedeco.javacpp-presets', name: 'opencv', version: '3.0.0-1.1', classifier: os
+        compile group: 'org.bytedeco', name: 'javacv', version: '1.2-SNAPSHOT'
+        compile group: 'org.bytedeco.javacpp-presets', name: 'opencv', version: '3.1.0-1.2-SNAPSHOT'
+        compile group: 'org.bytedeco.javacpp-presets', name: 'opencv', version: '3.1.0-1.2-SNAPSHOT', classifie
         compile group: 'org.bytedeco.javacpp-presets', name: 'opencv-3.0.0-1.1', classifier: 'linux-frc'
-        compile group: 'org.bytedeco.javacpp-presets', name: 'videoinput', version: '0.200-1.1', classifier: os
+        compile group: 'org.bytedeco.javacpp-presets', name: 'videoinput', version: '0.200-1.2-SNAPSHOT', class
         compile group: 'org.python', name: 'jython', version: '2.7.0'
         compile group: 'com.thoughtworks.xstream', name: 'xstream', version: '1.4.8'
         compile group: 'org.apache.commons', name: 'commons-lang3', version: '3.4'
Code:
./gradlew jar
find jar in
build/libs/GRIP-1.1.1-37-g39f1158.jar
