Go to Post If everyone spent half as much time reading and understanding the rules as they do complaining, arguing, and disagreeing about rules, we might not even be having this discussion. - AmyPrib [more]
Unread 09-02-2016, 22:42
alexusaywla alexusaywla is offline
AKA: Alexus
FRC #6155 (ElektraBots)
Rookie Year: 2016
alexusaywla is an unknown quantity at this point
Exclamation Autonomous Example
Can someone please provide me with an example of an autonomous code you've used before or are currently using? And please explain what everything means? As of right now I'm simply trying to drive during autonomous so even an explanation of how to program that will help. We are using VictorSPs to drive. I'll also appreciate any other help! I've searched through numerous sources but I am completely lost.
Unread 10-02-2016, 08:09
nollchr nollchr is offline
Rookie Year: 2014
nollchr is an unknown quantity at this point
Re: Autonomous Example
Are you using "Command Based" programming framework?
Unread 10-02-2016, 09:17
AKA: Alexus
Rookie Year: 2016
To my understanding no... I'm using SampleRobot. My current code can be found here so correct me if I'm wrong please http://pastebin.com/DQdALFKA. My autonomous is a mess!!
Unread 21-02-2016, 17:24
Dpurry23's Avatar
Dpurry23 Dpurry23 is offline
Programmer/Control System/Scout
AKA: Darian Purry
FRC #0207 (Metalcrafters)
Rookie Year: 2012
Dpurry23 is an unknown quantity at this point
It seems like you're trying to have multiple options for autonomous.
http://pastebin.com/8zBk4hG0
Look at the lines highlighted and I hope it helps
Unread 04-03-2016, 23:29
chesterm chesterm is offline
FRC #6055
chesterm is an unknown quantity at this point
try this for a simple straight ahead run in SampleRobot:
class declarations:
uint64_t autoTime = 0;
uint64_t testTime = 0;
void Autonomous()
if (IsAutonomous() && IsEnabled())
std::cout << "AutoMode START" << std::endl;
driveTrain.SetSafetyEnabled(true);
autoTime = GetFPGATime();
while (IsAutonomous() && IsEnabled())
testTime = GetFPGATime();
testTime = (testTime - autoTime) / 1000; //get milliseconds
if (testTime < 3250) //want to travel 11 feet in straight line
driveTrain.TankDrive(-0.65,-0.65); //drive forward
else
driveTrain.TankDrive(0.0,0.0); //stop
driveTrain.StopMotor();
std::cout << "AutoMode STOP" << std::endl;
