Go to Post The real question is not whether any teams have had metal in a speed controller, it's whether any teams haven't. - EricH [more]
Unread 10-02-2016, 02:31
Zaque Zaque is offline
FF: Bobo Brigade
AKA: Zachary H.
FRC #3352 (Flaming Monkeys)
Rookie Year: 2013
Zaque has a spectacular aura aboutZaque has a spectacular aura aboutZaque has a spectacular aura about
pic: Flaming Monkeys 2016 Power Take-Off Gearbox
Unread 10-02-2016, 02:32
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: pic: Flaming Monkeys 2016 Power Take-Off Gearbox
What made you go with a custom ballshifter shaft over the COTS options? What made you go with a belt pulley output over a shaft or sprocket output?
<Now accepting CAD requests and commissions>
Unread 10-02-2016, 02:55
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
whoops, misread
Unread 10-02-2016, 03:13
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
I imagine the ability to customize the length of the shaft to allow other gears to be placed on it. We are using a similar layout, and had to jump through some major hoops and do some weird things to make the COTS shifter shaft work. If we had the machining resources to build our own ball shifter shaft this season, we would have jumped on it in a heartbeat.
Custom can often be much simpler than COTS.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 10-02-2016, 10:49
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
FRC #1625 (Winnovation)
Team Role: Parent
Rookie Year: 2007
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
Go Monkeys Go!
See you a week from Sunday?
Do not panic! All is well!
- Kevin Bacon in Animal House
Unread 10-02-2016, 23:43
FF: Bobo Brigade
AKA: Zachary H.
Rookie Year: 2013
Originally Posted by neshera View Post
Go Monkeys Go!
Team members will be there. Robot will be there too if it's fully functional.
Zaque (Zach) H.
President
Programming/Electrical Lead
Unread 11-02-2016, 00:37
FF: Bobo Brigade
AKA: Zachary H.
Rookie Year: 2013
The main driving factor was actually price. These gearboxes are about half the cost of the rocketboxes or WCP DS with PTO. We also wanted the ability to fine tune the reduction and keep it compact while retaining 3 CIMS. The design we came up with required the ball shifting shaft to be driven directly by the motors, so we needed a custom shaft to keep the size small.
We are not set on belt output (lift system is most likely waiting until after bag), it was just in there for spacing.
Let me know if you have other questions or if that explanation was unclear.
Zaque (Zach) H.
President
