Go to Post Mentors can't get tired, it says so in the manual. SENIOR mentors, therefore, must have a different manual! - KathieK [more]
Unread 10-02-2016, 11:58
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Talon SRX CAN Connectors
What suggestions do you have for CAN connectors between Talon SRXs?
Last year we soldered all of the CAN connections. It took some time, but the CAN network was rock solid. We also did not have to change a Talon (knock on wood!).
This year, we've started using these latching polarized connectors from Hansen Hobbies. In some early testing, we found some drop outs on the CAN network. After many hours of testing we replaced a few connectors and the network seems OK.
I can imagine that much of the problem with the connectors is not the connectors themselves, but rather proper crimps on the pins. In any case, there's room for error that I am looking to remove.
What connectors are you using for your CAN?
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 10-02-2016, 12:46
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
Re: Talon SRX CAN Connectors
I've always loved Anderson PowerPoles:
http://www.powerwerx.com/anderson-po...d-housing.html
Unread 11-02-2016, 19:56
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
We use the same connectors but from digikey:
https://www.digikey.com/product-deta...2533-ND/210968
Unread 11-02-2016, 22:30
Justin Buist Justin Buist is offline
FRC #4003 (TriSonics)
Rookie Year: 2015
Justin Buist is an unknown quantity at this point
http://www.wago.us/products/terminal...ries/overview/
They seem to work well. A bit bulky and not easy to mount to a board but they work and are easy to swap out, add another controller to the CAN bus, etc. The student doing electrical on our team is the one that picked them to the best of my knowledge.
Unread 11-02-2016, 23:48
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Vex CAN connectors.
APPs are much too large for the CAN wires, both for crimping and impedance purposes. We considered using molex's new polarized genderless connectors, but as many of the can wires have to go into these sort of connectors on the RoboRIO, PDP, and PCM, it made sense to have all of the wire ends be the same and use these or at least something similar. These have an impedance selected specifically for CAN.
Unread 12-02-2016, 00:33
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Rookie Year: 2012
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Another vote for the CAN connectors from CTRE/Vex. Easy to mount somewhere and super simple to add/change/remove devices on your CAN chain.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 12-02-2016, 09:08
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
Rookie Year: 2013
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
This is how we did it last year: https://goo.gl/photos/53V8LWUjHWoYXNjz6
Male and female PWM connectors with a zip tie to secure it. It's not gendered, but the colors are a pretty easy match. This also lets you connect it to a PWM signal if you need to.
