Go to Post They showed me a new item and said "we don't know how to list this on the inventory." I took one look, started laughing and said "In my world that is called a game piece, aka, a tote." - RoboMom [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 10-02-2016, 15:17
hagay052 hagay052 is offline
FRC #3339 (BumbleB#3339)
Team Role: Operator
Rookie Year: 2013
hagay052 is an unknown quantity at this point
Exclamation Gyro fast drift problem
Hey everyone,
We have tried to measure the angle of our shooter using a gyro.
We had a problem with the gyro drift, after starting the program it immediately starts drifting at about 1 degree / 5 seconds.
How can we fix this problem? What may cause it?
Thank you
Unread 10-02-2016, 16:00
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Gyro fast drift problem
Consider using a pot or an absolute encoder instead.
We had a problem with the gyro drift...What may cause it?
Gyro drift is not uncommon. The sensor actually measures spin rate, which is then integrated in the FPGA.
after starting the program it immediately starts drifting at about 1 degree / 5 seconds. How can we fix this problem?
Make sure your gyro is warmed up to temperature and not being jostled when you calibrate it.
Or buy a very expensive gyro.
