Go to Post Who knew there were this many FRC teams that are teams! Very impressive, I might add. - [more]
Unread 10-02-2016, 16:26
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
Rookie Year: 2013
lethc will become famous soon enough
Defense/Carpet Sensor
So my team's looking for sensors to differentiate between the polycarb defense and the green carpet for use in autonomous. We're already in possession of some DM7-0N-1A photoelectric sensors. How well would these work for differentiating between the defenses and the carpet?
Another idea we had would be using some type of RGB sensor to pick up the green carpet only. Does anyone have a link to some kind of sensor that would work for this?
We'd likely be mounting the sensors a bit up into the robot so they can't get knocked around - this means that they'd have to have a decent range to always be picking up what's below them.
Is your team planning on using some type of sensor to differentiate between the defenses and the carpet? If so, please share
Thanks,
Becker
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 10-02-2016, 16:53
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Defense/Carpet Sensor
I haven't chatted with them about it lately, but our programmers were planning to try the accelerometer. When the robot's level again (plus another few inches counted by encoders), we're off the defense. We'll obviously have to have some sort of FSM system to evaluate yes, we're going up, now we're going over, now we're going down, and now we're across.
The visual rangefinder to the goals (camera + target processing) can also help determine if you're still in the outer works or not.
Unread 10-02-2016, 16:55
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Your best bet might be an accelerometer. Use it to sense the direction of gravity - if your on the defense, you'll likely be tilted in one direction or another (except for that split second your at the top of the defense driving over it).
A photoelectric sensor might work, too - shine a light down, and measure how much is returned. You might find there's a big enough different between carpet and the defense, but that would definitely require some on-field calibration.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 10-02-2016, 17:02
DanielPlotas DanielPlotas is offline
FRC #1984 (Raider Revolution Robotics)
Rookie Year: 2012
DanielPlotas will become famous soon enoughDanielPlotas will become famous soon enough
The field line sensors (not sure of the actual name) from the 2011 kop will be able to differentiate between the defense and the carpet. We have used then in previous years and they are quite useful (except for when the GDC puts black tape on grey carpet) Based off your team number, you probably still have them in some dusty corner. If not, we'd be happy to lend you one or two.
Sleep? What is that? A rare Pokemon?
Unread 10-02-2016, 20:06
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
I assume you referring to the Allen Bradly 42EF-D1MNAK-A2?
We have had success so far being able to differentiate between the green gaffers tape and the green carpet using it, so it should also be able to tell whether or not your are on a defense as well.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 10-02-2016, 23:16
Rookie Year: 2012
Yep that's them. Last year we tried using two of them on the sides of our chassis to automatically line up on the scoring platform and drop a stack. It didn't work out for other unrelated reasons.
We have decided not to use them, as they need to be close to the ground to work well, and we are using pneumatic wheels.
What kind of drivetrain are you using?
How far off the ground are you having yours?
Unread 11-02-2016, 00:06
wt200999's Avatar
Texas Instruments
AKA: Will Toth
We haven't tried it on our actual bot yet, but testing with just the sensor in different lighting conditions showed it was reliable to ~2.5" from the carpet/tape, which is around the height I expect to have ours mounted. This was with only rough tuning of the adjustment dial on the top, so it can certainly use more experimentation.
Unread 19-02-2016, 17:22
Louisiana Jones's Avatar
Louisiana Jones Louisiana Jones is offline
Jason Jones
AKA: Jason Jones
Team Role: Coach
Rookie Year: 2013
Louisiana Jones will become famous soon enoughLouisiana Jones will become famous soon enough
We are also using pneumatic wheels, and after measuring it looks like we could get them as close as 1.5 inches, but more likely if we wanted to keep the sensor protected it would have to be higher than that.
Unread 19-02-2016, 17:31
Jason Jones
AKA: Jason Jones
Team Role: Coach
Rookie Year: 2013
That's to bad because we would like to mount them a little further away,but I think we can make 2.5 inches work.
Unread 19-02-2016, 17:50
MrRoboSteve MrRoboSteve is online now
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Put LED lighting under the robot to help with lighting condition variances.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 19-02-2016, 19:34
wt200999's Avatar
Texas Instruments
AKA: Will Toth
With some additional adjustments I was able to get the detection working significantly further away, though I still have not done it on the actual robot. (Hopefully that will happen in the next week.)
I tried doing this in both dark and bright environments with the big ring lights, but I did not observe any difference between the two with or without the light.
