Re: FRC 95, The Grasshoppers, Build Thread
Are you planning to intake from both sides? Is there any significant advantage, that your team saw, to that strategy (if you are indeed capable of intaking from both sides)?
Though your point is well-taken. The versaplanetary guide is to be taken quite seriously! |
A close-up of the shooter.
![]() It's a bit... different... than most shooters we've seen before. We've setup the first 'booster' stage (3/4 of the length) to ramp up in speed as it feeds into the 'firing' stage, which spins considerably faster. Prototype testing has been quite promising. |
A few pictures from today:
The shooter is nominally populated with belts and rollers and stuck on the robot! ![]() How he'll be able to fit under the low bar. ![]() Wiring is about 70% there, enough for a power-up test! ![]() We're currently trying to get code on the Athena (we refuse to call it the "Roborio"), which always seems to have some growing pains. We'll get there... |
A team after my own heart.
Man, I love 95's robots. You guys always put out something beautiful and unique.
I love seeing this thread every year. 95 is always evolving and improving. Good luck in 2016!
Thank you! It is what we strive for, at least in baby steps. And good luck to the Rocketeers! |
#10
RE the dual lock on the electronics - you sure that'll hold everything tight when crossing defenses?
Looks good again this year man. |
#11
And thanks! |
#12
Wow, that's a really creative design in a game with many similarly designed low bar bots. We'll be seeing you guys at Granite State, good luck!
#13
Started our drive-train burn-in only to have the burn-in go a little too literal for us...
Side plate off to investigate: ![]() Yeah... had some rubbing chain tensioners... ![]() Milled them down, reassembled, and tried out some defenses. Moat Low Bar Did some crossing exercises, everything looked good, until... ![]() Weirdest chain failure I've seen, and the only one I've ever had on a 95 robot. Master-link was good, fractures are on opposite sides of the chain loop, tensioners were installed and slack(ish), and our nominal FoS is around 4 or 5. Bizarre... Last edited by JamesCH95 : 17-02-2016 at 14:29. |
#14
This was my biggest concern, along with cracking wheels, when designing this year. I would suggest getting a lot of spares for competition. Going over the obstacles and slamming into the ground will definitely break chain, as you saw first hand. At least it happened now and not at a competition. |
#15
