Go to Post I, for one, refused to be railroaded down this train of thought so easily! Geeze, one lousy game hint just builds up steam for any old picture to come through and go two pages in a matter of hours. - Billfred [more]
Unread 10-02-2016, 20:08
Kevin Pai's Avatar
Kevin Pai Kevin Pai is offline
FRC #5964 (Praetorians)
Rookie Year: 2015
Kevin Pai is an unknown quantity at this point
Adjusting Joystick Sensivity in Java
Its ya boy Kevin Pai coming at you, I was wondering how to adjust the sensitivity of the joystick to slow down its acceleration.
Unread 10-02-2016, 20:16
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Adjusting Joystick Sensivity in Java
It's unclear what you want.
Do you want the motor voltage to ramp up at a limited rate when you make large changes in command?
Or do you simply want to limit the maximum command that the joysticks can issue?
Unread 10-02-2016, 20:36
Kevin Pai's Avatar
Rookie Year: 2015
Yeah sorry for being unclear, I want to to be able to moderate the speed of a motor by changing voltage based on joystick movement. We have to be able to move the robot with slower acceleration because our joystick is too sensitive.
Unread 10-02-2016, 20:57
Ether's Avatar
Rookie Year: 1969
Does this help?
http://www.chiefdelphi.com/media/papers/2421
