Go to Post Be thankful for what you have, not frustrated with it because it doesn't exactly suit your needs. - sanddrag [more]
Unread 10-02-2016, 22:39
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
Rookie Year: 2013
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
Messed up CUI order
I bought 4 CUI encoders at Digikey, with axial connections (AMT103-V). Recently, the CAD team informed me that we need 2 axial and 2 radial. Being in Chile and 12 days from stop build day, I can't order new ones, especially with the very expensive shipping cost to Chile.
So has anyone here accidentally bought the wrong encoder and modified the pins with success?
FRC 2576 2015-???: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2013: Gracious Professionalism Award | Los Angeles Regional 2014: Regional Chairman's Award
Unread 10-02-2016, 22:50
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Re: Messed up CUI order
You could solder wires directly to the pins of the encoder. We've done that before when we didn't have the connector.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
Unread 10-02-2016, 23:01
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
I always use a clip-on heat sink when I do that. In a pinch, a large alligator clip is better than nothing.
Make sure to clip the heat sink between the encoder and the solder joint.
