Go to Post Engineering is a fabulous background for many careers. - dtengineering [more]
Unread 11-02-2016, 06:55
Nitay's Avatar
Nitay Nitay is offline
Moving FIRST Forward
AKA: Nitay Sheffer
FRC #1574 (MisCar)
Rookie Year: 2010
Nitay is an unknown quantity at this point
Reading data from VEXpro VersaPlanetary Integrated Encoder
Hi,
We have just received the new VEXpro VersaPlanetary Integrated Encoder, and we were trying to read data values from it. Since it can only connect to the new Talons and not to the actual roboRIO, we were wondering how can we connect to it.
Any ideas will be greatly appreciated.
Thank you,
Nitay
MisCar 1574
Unread 11-02-2016, 07:22
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Captain
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
Rookie Year: 2014
nickbrickmaster is an unknown quantity at this point
Re: Reading data from VEXpro VersaPlanetary Integrated Encoder
You'll need an encoder breakout board. http://www.vexrobotics.com/217-4398.html
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 11-02-2016, 07:33
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
And/or connect directly to a Talon SRX that you're controlling through CAN. Then you can read it off the Talon. If you're not already using Talon SRXs through CAN, then go with the breakout board.
Unread 11-02-2016, 07:34
Nitay's Avatar
AKA: Nitay Sheffer
FRC #1574 (MisCar)
Rookie Year: 2010
OK, We do have this board, but what do we do in the LabVIEW code?
Unread 11-02-2016, 09:51
Allthatslack Allthatslack is offline
None #1389
Allthatslack is an unknown quantity at this point
Hi, electrical team leader from 1389. We are using 12 Talon SRX's and a lot of versaplanetary gear boxes. Would you like me to talk to the lead programmer and ask him what he did to program them? We are not using the encoder breakout board, the Talon's and encoders are connected directly to each other.
Unread 11-02-2016, 11:06
Captain
AKA: Nick Schatz
Rookie Year: 2014
When you hook up the breakout board to DIO, it should function as a normal quadrature encoder.
Unread 12-02-2016, 06:43
Nitay's Avatar
AKA: Nitay Sheffer
FRC #1574 (MisCar)
Rookie Year: 2010
Hey, I'd love to see a bit of code, thanks
Unread 16-02-2016, 16:53
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Team Role: Coach
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
same here... we are using the cable ribbon from the encoder to the talon SRX connected through the RIO via CAN... but have no idea on the coding... any help to get us started would be very much appreciated... is there an app on laptop we can use to "see" the encoder value?
Thanks a bunch
Unread 16-02-2016, 20:06
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Thanks a bunch
Did you try the manufacturer's website [it's labeled on the product ]?
http://www.ctr-electronics.com/talon...ical_resources
