Go to Post I am definitely as much a student as any one of the kids on the team. - Hieb [more]
Unread 11-02-2016, 16:59
mattoreo310 mattoreo310 is offline
FRC #4012
mattoreo310 is an unknown quantity at this point
Post Build error while deplyoing to roboRio (Eclipse, c++)
Hello,
So after 3 days of issues regarding deploying our build code to the roboRio, I'm getting kind of frustrated with the repeated build errors we were receiving.
Originally, we started getting a permission error regarding deploying code to the roboRio that was shown like this in eclipse:
We've assumed this was regarding a permission error & tried editing the roboRio through its web address page, putting a pass on admin.
Buildfile: C:\Users\Robotics Team 4012\workspace\Tank\Tank\build.xml
Trying to override old definition of task classloader
get-target-ip:
[echo] Trying Target: roboRIO-4012-FRC.local
[echo] roboRIO found via mDNS
dependencies:
[echo] roboRIO image version validated
deploy:
[sshexec] Connecting to roboRIO-4012-FRC.local:22
[sshexec] cmd : rm -f /home/lvuser/FRCUserProgram
[sshexec] Could not chdir to home directory /home/lvuser: Permission denied
[sshexec] rm: can't stat '/home/lvuser/FRCUserProgram': Permission denied
[sshexec] Remote command failed with exit status 1
[echo] [athena-deploy] Copying code over.
[scp] Connecting to roboRIO-4012-FRC.local:22
BUILD FAILED
C:\Users\Robotics Team 4012\wpilib\cpp\current\ant\build.xml:67: com.jcraft.jsch.JSchException: Could not send 'C:\Users\Robotics Team 4012\workspace\Tank\Tank\Debug\FRCUserProgram' to '/home/lvuser' - 3: Permission denied
After a while of receiving this same error and verifying that our eclipse was setup correctly & the robot was imaged to 2016 we changed computers.
And now we receive a new error:
BUILD FAILED
C:\Users\Robotics\wpilib\cpp\current\ant\build.xml :45: Assertion failed boolean test.
roboRIO not found, please check that the roboRIO is connected, imaged and that the team number is set properly in Eclipse
At this point we are not too sure what the problem is and are considering calling National Instruments, any help?
Thanks.
