Go to Post It's not GP, its not un-GP, its just a strategy. - AndyB [more]
Unread 11-02-2016, 18:40
Minerbotics4827 Minerbotics4827 is offline
FRC #4827
Minerbotics4827 is an unknown quantity at this point
Compressor won't turn off - PCM?
This year is our first using pneumatics, and we are encountering an odd problem. When we first set everything up to test, the compressor turned on and off just as it was supposed to, but now that everything has been transferred onto our robot it doesn't. The compressor and pressure switch are both plugged in properly and there is a solenoid opened in the code, but the compressor won't turn off once it reaches the maximum pressure. It actually turns on even when the pressure switch isn't plugged into the PCM. I have already tried updating the firmware on the PCM to both 1.62 and 1.65. If anyone can help us figure out the problem, you'd be amazing!
Unread 11-02-2016, 18:53
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Rookie Year: 2013
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Re: Compressor won't turn off - PCM?
Have you checked your pressure relief valve (the one with the hole/holes) to see if it is letting air out before the pressure switch can trigger? If not, that might be one reason. But that is really weird if the pressure switch is disconnected and it still runs. If it isn't the relief valve, I would guess that you might have a faulty PCM.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 11-02-2016, 21:14
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Try a new PCM. If there is no switch, then the it should not turn on.
Unread 11-02-2016, 21:22
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I'll echo this. Also, contact CTRE about it - this is a bad/dangerous failure mode for the PCM, and they may want to investigate why it's acting this way.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 11-02-2016, 21:49
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Check the power wires to the compressor and pressure sensor where they connect to the pcm, we had a similar issue caused by exposed wire contacting at the pcm
Unread 11-02-2016, 23:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
I agree - check for swarf (metal shavings) or another source of a short across the pressure switch terminals. If you can't find anything, replace the PCM, preferably working with the vendor or CTRE.
Unread 12-02-2016, 00:02
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
Another thing to check: make sure the pressure switch isn't shorted out; with the compressor running, unplug the switch. If the compressor keeps running, it's a PCM issue (or swarf intrusion as some have mentioned). If not, the switch or its wiring is shorting out.
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 12-02-2016, 19:09
FRC #4827
We have unplugged and replugged everything in three times, checking for shorts every time. We didn't find any metal shavings, and even took the PCM apart trying to find any. Even if we unplug the pressure switch while the compressor is running, the compressor stays on. We are ordering a new PCM to test tonight. Until then, we have the pressure switch plugged in as a digital input and are controlling the compressor through code in teleop while we test.
Unread 12-02-2016, 20:31
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Don't forget that for competition you need to either switch back to a PCM or put the compressor on a spike (R88 C and D).
Unread 12-02-2016, 23:32
ratdude747's Avatar
AKA: Larry Bolan
Yeah, I'd RMA that PCM. That's clearly a PCM issue.
