Go to Post Time flies when you're freaking out. - Koko Ed [more]
Unread 11-02-2016, 18:45
hwu24110 hwu24110 is offline
FRC #0988
hwu24110 is an unknown quantity at this point
Twitchy Motors
So we have another problem with the roborio (the connection issue is fixed). I noticed that the motors twitch, regardless if it is a Talon SR or VIctor SP. We have tried another schools Talon SRs and PWMs, it still twitches, so I think it may be an issue with the wiring or the physical roborio. It is not a shortage since the electronics board is mounted on a wooden board and the only wires touching the metal frame are the motor wires and the battery cables, which I am fairly sure is not causing the issue.
