Go to Post I really think we need to keep our pitchforks sheathed and torches unlit until we here more news and get more details. - IndySam [more]
Unread 12-02-2016, 13:49
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Sheet Metal Brake
Our team is interested in purchasing a sheet metal brake. There was a similar thread a couple years back here. Wanted to revive that discussion.
We want a box & pan brake (as opposed to a press brake). Ideally we'd be able to bend up to 0.09" aluminum. My best understanding indicates that's roughly equivalent to a capacity of 12 ga. for mild steel. We want something at least 3' wide. There isn't a budget for this right now, but some searches indicate it would need to be in the range of a few thousand dollars.
What are reputable sheet metal machine brands?
With sheet metal brakes, would it be better to buy used?
If you have a brake with similar specifications, what brand/model is it and do you like it?
An initial search suggests these two might be good. I've also used a Tennsmith I liked. Any thoughts on those in particular?
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 12-02-2016, 14:01
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Re: Sheet Metal Brake
When you get one make sure you look into getting fingers with a radius. We retrofitted our Chicago 412-6 with new 3/32 radius fingers and it works much better. The only catch is that the new fingers were close to $1000 by themselves. Perhaps see if you can order with these kinds of fingers.
We bend a great deal of aluminum with it. Our designs are based on using flat sheet cut on our waterjet and the brake.
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 12-02-2016, 14:48
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If you don't have the larger radius fingers, you can put a piece of aluminum under them to increase the radius...but it's kind of a flaky way to do it.
you meant 3' not 3" wide, right?
Unread 12-02-2016, 15:21
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Spinal Tap made a mistake like that...
Unread 12-02-2016, 15:32
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
we have that same Baileigh brake the BB-4012.
it works well but the only caution I have is that the fingers and the table are NOT hardened steel. You can dent them if not used properly.
We have a God knows how old 24 inch desk top box and pan brake that has fingers that look like new yet, they are hardened.
If you go with the Baileigh make sure you get the educational discount.
the one thing nice about the Beileigh is that it is counterballanced with springs rather than weights. Much more compact and you can't accidentally conk somebody on the head with a 15 lb weight.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 12-02-2016, 16:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We have an old Pexto box and pan brake that's about 24" wide capacity and weighs probably 600 lbs. We did 1/8" 5052 on it yesterday with a tiny radius set of dies and it went pretty nicely.
Unread 13-02-2016, 16:27
Basel A's Avatar
AKA: @BaselThe2nd
Interesting, thanks for the tips. We'll definitely keep an eye out for that then.
We've had relative success with lots of tube designs, but this year discovered just how quickly we can put things together with plasma-cutting and bending. Having a brake in-house would accelerate that to another level.
And yes, I did mean 3', although I suppose that's included under "at least 3 inches"
Good tip, thanks. How long have you had it? It has held up well?
The previous thread mentioned Pexto as a good brand. Is it this one?
-Paul Copioli
Unread 15-02-2016, 14:45
Bruceb's Avatar
we have had the Baileigh about 2 years
lots of dings and scratches because it is not hardened but the rest is fine
it will easily bend .125 5052.
