Go to Post Someday I will have to learn how tagging and reps work. I already know how search and brain farts work. - kstl99 [more]
Unread 12-02-2016, 17:16
ICE_Bear ICE_Bear is offline
FRC #5875 (ICE)
Rookie Year: 2014
ICE_Bear is an unknown quantity at this point
Bumpers- Pool Noodles and Bumpers
We are unsure of how to connect the pool noodles to the plywood to make our bumpers legal. We've seen some posts about just pulling the fabric really tight, in which case do we need extra cloth before the colored cloth? Also, there are rules against using tape or any other material that could compress the noodles. Are we allowed or not?
Unread 12-02-2016, 19:53
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Rookie Year: 2014
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Bumpers- Pool Noodles and Bumpers
http://www.chiefdelphi.com/forums/sh...d.php?t=140559
Take a look at above
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 12-02-2016, 19:55
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
You can tape the noodles to the wood, you just can't tightly wrap the tape around the noodles to compress them. The bumper rules specifically allow soft fasteners to be used for this purpose.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 12-02-2016, 20:07
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Rookie Year: 2012
Robo Hamsters is an unknown quantity at this point
We have used hot glue to hold them in place while we attach the fabric.
FRC 4466
FTC 7042
2013 Washington DC Regional Finalist
Unread 12-02-2016, 21:10
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
We've never used any fasteners or tape. If the bumpers are fitted around the corner (most years), we stuff the noodles inside then add the wood "bracket" or "box", hand stretch, and staple.
The one time we did straight bumpers (no corners), we laid the fabric down on a table, put the noodles on top, put the wood on top of that, compressed SLIGHTLY (enough to secure the wood, not enough to deform the noodles more than 1/4" or so) with a large pair of C-clamps, then pulled up the fabric snug and stapled, long sides first, center out. When we released the c-clamps, the fabric tightened as the noodle opened back up.
