Go to Post Yes, a big part of FIRST is learning from others. But a just as important part of FIRST is learning from discovery. - [more]
Unread 13-02-2016, 00:08
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
CAN Talon and Bang Bang Controller
Has anyone had success with a bang bang controller with the CAN Talon speed controllers?
Our results were less than spectacular. The lag time for reading and setting the talons was noticeably slow so that you could tell even by listening that the motor was rotating over a large range of speed. I don't recall the graph values but the results were were over a large range.
We were also using an unloaded motor. The motor was on a bench with nothing attached to the shaft.
Any thoughts would be great to consider.
Thanks
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
