Go to Post Dangit Jim, we are engineers not politicians. - Andrew Schreiber [more]
Unread 13-02-2016, 09:59
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld is an unknown quantity at this point
Elastic Potential Energy Stored in Surgical Tubing: What are the legal limits?
We want to project our arm that will hook on the castle tower's bar. We want to do this vertically using surgical tubing to lift the arm until it hits the stop at the top of the arm's travel. It never gets "airborne" and stays completely within the confines of its mechanism. Our question is: Is there anything prohibiting using surgical tubing, stretched and secured at the arm's base, as the means of extending the arm in the last 20 seconds. (we will have a latch mechanism in place to be sure that it won't release until our driver hits the button.) Thank you.
Unread 13-02-2016, 10:02
AngryCalculator's Avatar
AngryCalculator AngryCalculator is offline
looking for the 7/16 wrench
AKA: Andy Gothro
FRC #2910 (Jack-In-The-Bot)
Team Role: CAD
Rookie Year: 2011
AngryCalculator is an unknown quantity at this point
Re: Elastic Potential Energy Stored in Surgical Tubing: What are the legal limits?
Nope. It should be fine; 2910 plans on using it too.
"who relabeled the white lithium grease as spray-on coffee creamer??"
Unread 13-02-2016, 10:07
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
You are specifically allowed to do this as per R35
Originally Posted by Rules
R35 Non-electrical sources of energy used by the ROBOT, (i.e., stored at the start of a MATCH), shall come only from the following sources: A. compressed air stored in the pneumatic system that has been charged in compliance with R79 and R80, B. a change in the altitude of the ROBOT center of gravity, C. storage achieved by deformation of ROBOT parts,
D. closed-loop COTS pneumatic (gas) shocks, and E. air-filled (pneumatic) wheels
What you need to be concerned with is R9
R9 ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS.
Inspectors will look very closely at your mechanism to ensure that it is safe at all times. This includes when it is being transported on/off the field as well as in the pits, etc.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 13-02-2016, 11:02
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Regarding R9:
If there will be a lot of tension put on the tubing, then you will need a safety mechanism in case the tubing breaks. Basically unplanned sudden release of stored energy must be taken into account.
In the past, encasing the tubing in tube would suffice. Make sure the outside tube has a separate attachment so that it won't go flying off either.
Unread 13-02-2016, 19:38
FRC #5523
Thanks. Looking forward to seeing how you use it, too.
Unread 13-02-2016, 19:40
FRC #5523
Thank you. Just what we needed. Good advice, too.
FRC #5523
Originally Posted by rich2202 View Post
Regarding R9:
Great idea. Thank you. Didn't think of that.
Unread 13-02-2016, 19:52
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We have an assembly that works. We abandoned our climber due to our winch being all messed up though.
Unread 13-02-2016, 20:24
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
From a practical standpoint, you probably don't want to stretch the surgical tubing much past twice its natural length; beyond this it tends to stretch inelastically*, especially if held there for a long time.
* that is, a permanent stretch, from which it will not return to its original length.
Unread 13-02-2016, 20:37
FRC #5523
Very important point. Thank you so much.
