Go to Post Just because its a robotics competition does not mean everybody is a big dork. - Taxi Quinn [more]
Unread 02-13-2016, 12:07 PM
rcdturtle rcdturtle is offline
rcdturtle
AKA: Dick DuCharme
FRC #3534 (House of Cards)
Rookie Year: 2011
rcdturtle is an unknown quantity at this point
SRX Position Control Confusion
We are attempting to control a gear with a rotation range of about 180 degrees in a subsystem called Pivot. We are using joystick input to manually move the gear by bumping the position each cycle the joystick method is called. This allows the pivot to remain at the last joystick commanded position as barriers are crossed. That code is at the bottom of the attachment. It works just as intended.
Our problem occurs when we attempt to progmatically send the pivot to a particular position. We are attempting to read the current position of the gear, determine the difference between the current and commanded positions and use the difference with a SET() command to move to the desired position.
Apparently we don't understand something because every time we execute the SetPivotAngle command the gear rotates constantly. This is true even though the IsFinished requirements are met in the command.
The code is below as you can see we have made several stabs at it.
Thanks in advance for your help.
Unread 02-13-2016, 01:22 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: SRX Position Control Confusion
Where is angle defined, and where is it set?
Unread 02-13-2016, 02:55 PM
rcdturtle
AKA: Dick DuCharme
Rookie Year: 2011
Sorry we didn't send all of the SetPivotAngle code. The variable angle comes as a parameter when the command SetPivotAngle is instantiated in OI or as part of a group command; it is in degrees of gear position.
