Go to Post Robot: Gyro, please reset yourself and verify proper operation. Gyro: ... WHY IS THE EVERYTHING SPINNING SO FAST? HELP! ... Robot: Are you working yet? How about now? - EricVanWyk [more]
Unread 13-02-2016, 14:22
Potatonator's Avatar
Potatonator Potatonator is offline
much potato very robot wow
FRC #4360 (Spudnik)
Rookie Year: 2012
Potatonator is an unknown quantity at this point
Problem with connecting to roboRIO
Hi!
We've encountered an issue where our computer is not communicating properly with the roboRIO. I made a post asking about this, but deleted it because we thought it was fixed, but apparently it isn't...This is the error we got:
Code:
BUILD FAILED
C:\Users\Spudnik_Commander\wpilib\java\current\ant\build.xml:208:
Assertion failed boolean test. roboRIO Image does not match plugin, allowed
 image version: 19
(Yes, I did type out the entire error message because I'm posting on a different computer than the one we used for coding.) We were thinking that it's an issue with the Java version on the computer and the roboRIO not matching. Is that correct, and if so, which one should we change? Is it something totally different? We tried reinstalling the JRE on the roboRIO, but we still got the same error.
Thanks!
Unread 13-02-2016, 14:35
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Re: Problem with connecting to roboRIO
It is not that you have a different version of Java, it's that you have the wrong RoboRIO image installed. You'll want to use the RoboRIO imaging tool to update it to this year's image.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 13-02-2016, 14:48
FRC #4360 (Spudnik)
Rookie Year: 2012
We tried that, and it seems to be working. Thanks!
