Go to Post DEKA is right next to the river, and when i got there this morning they wouldn't let us into the building, but apparently there is and standing water on the first floor. The ironic thing is that i work on the water project and we can't deal with a bit of water on the floor - Greg Needel [more]
Unread 13-02-2016, 14:29
koreamaniac101's Avatar
koreamaniac101 koreamaniac101 is offline
Founder and Team Leader
AKA: Soohan Kim
FRC #5938 (Razor Steel Robotics 4-H Club)
Team Role: Leadership
Rookie Year: 2016
koreamaniac101 is an unknown quantity at this point
Bumper Length Rules (Another One)...
First, let me apologize for another bumper post. I know there are tons being posted all season, but the rules for bumpers are truly unclear, and my team needs to be 101% sure that our robot is non-compliant before starting a major redesign (at the end of Week 5)
So, the original rule R19 states " If a side is shorter than 8 inches, then the entire side must be protected by BUMPER". See figure 4-3.
In update 5 to the rule book issued on Jan 26, the updated figure 4-3 has three arrows to the figure now instead of two. The middle arrow looks like it is stating that a side less than 8 inches is no longer acceptable? Is this correct?
Unread 13-02-2016, 14:35
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
Re: Bumper Length Rules (Another One)...
Your side is not 4 inches in the picture its from #4 on your tape measure all the way to the other side of your robot way over on the left. You need 8 inches of bumper on each corner. You will need 4 more inches of bumper and frame on each side to be compliant.
2002-2005 Appleton East High School: Team 93
2005-2011 Michigan Technological University: Team 857
2012-2016 Wave Robotics Team 2826
Unread 13-02-2016, 15:41
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Team Role: Mechanical
Rookie Year: 2016
Type is an unknown quantity at this point
The side of your robot is greater than 8". When measuring for sides, if you put a string around your robot, that determines your sides and perimeter. Since from corner to corner, that is larger than 8", you need at least 8" on each corner. Hopefully this makes sense.
Unread 13-02-2016, 15:47
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Rookie Year: 2014
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
To summarize and to try to help..for your bot (as for best guess from your picture)
Each front corner will need an 8" bumper side. In other words, The front of your bot will have to have 16" of bumpers with 8" per corner.
The issue you will run into based on what I see, is that the shooter will very likely, hit the bumper as it raises and lowers. So take that into account as I don't see it working as configured in pic. You may have to make your bot wider (or add 4"+ mounting extensions on side) to avoid the shooter hitting your front bumper or you may have to move your shooter forward so wheels are past the front bumper up to 15" forward of frame perimeter.
There is no way around the 8" per corner of bumper in your case based on what I see.
Hope that helps.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star #21 | Galileo Division #91
Unread 13-02-2016, 15:51
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Let's see if this makes it any clearer. Take a long piece of string (actually, surgical tubing might be better) and wrap it around your frame, pulling tight. From each corner formed in that string, measure 8". Mark the frame in that location. Can't mark the frame, because it isn't there? You'll need to put something there. By the way, that string is the frame perimeter.
Any side of the frame perimeter that is <16" between corners will need bumper along its entire length due to the required 8" of bumper from each corner.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 13-02-2016, 21:50
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by koreamaniac101 View Post
...but the rules for bumpers are truly unclear...
Not to me.
Anyway, your FRAME PERIMETER looks to be about 28 inches (not 4) on the side facing the camera.
Use the string mentioned above to find the FRAME PERIMETER, which is not in any way related to your actual metal frame (aside from both being on your robot). Be sure to do this in your BUMPER ZONE, btw.
Why do I put some words in UPPERCASE? These are specifically defined things...read the rules to see what they mean. If you don't, then I agree things may be unclear to you.
Unread 14-02-2016, 15:18
Hugekase Hugekase is offline
FRC #1359 (Scalawags)
Team Role: Student
Rookie Year: 2013
Hugekase is an unknown quantity at this point
Bumper Length stuff may have been changed, Click here for team updates.
Unread 14-02-2016, 15:37
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
The Team Updates have been clarifying the the bumper rules. The fundamental principles upon which these rules are based on have not been changed by the updates. Unfortunately, I don't believe that the updates magically makes the OP's bumpers (and those of quite a few other teams) legal.
Unread 14-02-2016, 15:59
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Soohan,
Others have been pretty clear but let me confirm your robot is illegal unless you put 8" of bumper in each corner. There is no gray area.
If the string you wrap around your robot is longer on a side than 8" than you need to have at least 8" on either corner.
So if your side is shorter than 16" then that side needs all bumper.
Sorry but it looks like you need a redesign.
One last thing: the plywood part of the bumper needs to be at least 8".
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 14-02-2016, 16:40
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Amazing...
"Side" is defined... Those pieces in the front of this robot are not sides....
they are parts of a side. Each must be 8" wide....
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 14-02-2016, 16:46
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Originally Posted by Paul Copioli View Post
Soohan,
...snip...
Just to be exceedingly specific:
The plywood part needs to be at least 8 inches from the corner of the FRAME PERIMETER. As an inspector, I have often come across robots with 8 inches of plywood, but 3/4" overlapping in one corner. This overlap causing one side to be only 7 1/4" and thus illegal.
There may be some methods that will likely be less painful for your redesign should you be interested in entertaining them. If you have some extra inches of frame perimeter, there are some methods you can do to reduce the impact on your intake.
For the record, I am not sure who it is in the picture, but I am very familiar with that look. It is the "Now what do we do" look which often occurs when things get real in week 5.
The great news for you is.... Its week 5, you still have a good chunk of time to deal with this issue and make corrections. As an LRI, I have seen this bad of an issue hours before competition was to start, and the team came through and still had a good weekend. Take a deep breath, a hard gulp, and start the work to fix it. Spend 30 minutes and brainstorm all the ways you can "correct" it, and discuss the pros and cons of each, pick a direction and get to it.
