Go to Post I'm sure someone somewhere worked [I]really hard[/I] on this and I congratulate them for the attempt. Unfortunately, its one of those things that should be taken down and recorded in the company journal as a bad idea. - Katie_UPS [more]
Unread 13-02-2016, 15:47
Amit3339 Amit3339 is offline
B B BumleB
FRC #3339
Team Role: Leadership
Rookie Year: 2011
Amit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to behold
Talon Stable RPM Check
We used the code of the Talon CAN rpm to reach a certain rpm every time but having a problem to check if the rpm is stable. We programmed a block that check's if the rpm is stable for 4 times( with a clearance of +-100) but were wondering if there's a better for doing this check?
Thanks in advance!
2016- Team Captain, Driver & Programming Crew Member
Championship Curie Sub-division Winners| Curie division
Regional Winners | Israeli Regional
2015- Driver & Programming Crew Member
Championship Carson Sub-division Winners| Carson division
Excellence in Engineering Award sponsored by Delphi | Israeli Regional
2014- Driver & Programming Crew Member
