Go to Post You only really ever need 2 things in your tool box: A Hammer to separate things that shouldn't be together, and Duct Tape to put things together that shouldn't be apart. - Dave_222 [more]
Unread 02-13-2016, 09:39 PM
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
Rookie Year: 2013
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
Connecting Raspberry Pi to network?
Is there any thing saying that it is not allowed to have a Raspberry Pi have a WiFi adapter to connect it to the the robot's wifi network? I was planning on using 1 of the 2 ethernet ports on the router for the network camera (other for the roboRIO, and connect the Pi to the robot's network wirelessly so my team didn't have to buy a network switch and wait for it to be delivered.
Unread 02-13-2016, 09:49 PM
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
Re: Connecting Raspberry Pi to network?
I'm 100% sure that wouldn't be allowed or work at competition.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
"Head Bot Coach" FRC Team 4901 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1102, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 02-13-2016, 09:56 PM
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
I highly encourage you to check out R63 to determine whether or not it would even be legal.
Even if it were legal, remember that the radio is programmed to be in bridge mode at competitions. Teams have no access to the WPA keys used by the field, so even if you got it working back home, once you got to the competition, you wouldn't be able to connect to that network anymore.
I'm right 90% of the time, so why worry about the other 3%?
Unread 02-13-2016, 11:48 PM
JohnM's Avatar
FRC #5854 (Glitch)
Rookie Year: 2013
Ah yeah, forgot about this.
Thanks!
Unread 02-14-2016, 08:02 AM
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Actually, you do have access to your key. But, since you shouldn't be connecting to the FMS wifi network with other devices, I won't tell you how.
Unread 02-14-2016, 08:45 AM
dpotteiger dpotteiger is offline
FRC #2377
Rookie Year: 2015
dpotteiger is an unknown quantity at this point
You could purchase a mini switch as (http://www.amazon.com/Linkskey-5-Por...dp/B001BEFRBQ), power it through your VRM (careful to make certain it is connected to the correct voltage and polarity). Connect an Ethernet cable between one of the switch outputs to the available radio port. Then connect your camera and pi to the other two using Ethernet cables.
