programming for brownout avoidance
Our team is using a 6 cim drive for the first time and we are of course finding it quite easy to brown out when approaching full throttle from a stop and in turns in high gear.
I don't want to discuss the relative merits of 6 cim vs. 4 cim. The team wanted to do this and I lost the argument. ![]() Ive looked in all my usual places for this and have come up empty. The question is: In LabView how do we:
Re: programming for brownout avoidance
Does this help?
1) Process that reads the voltage, and adjusts a "Power Factor" variable. For example, when voltage is > 9 volts, Power Factor = 1. When it drops below that, the value declines. 2) In your process that sets the speed of the motors (let's say the value is Speed), multiply that number by the Power Factor variable (Speed * Power Factor). Last edited by rich2202 : 14-02-2016 at 08:25. |
Do you think this process would work best in Periodic Tasks or Teleop? |
I have no idea of the differences between Periodic Tasks and Teleop. Our team uses C++, and everything is done in TeleopPeriodic.
If you want to check it each time you update the motors, then doing it in the same place might make sense.
If you are using Command and Control, that is likely in the Drive Controller Code. Otherwise it is likely in the TeleOp code. Unless you are doing it at a slower rate, I wouldn't Periodic Tasks. Greg McKaskle |
But then the programmers wouldn't get to have so much fun Good luck! |
We just finished putting joystick ramping on the drive to help with the rocking -- in case the drivers want it. It will also help with surge current and is perhaps simpler than the previously described algorithm. You could even decide to keep a running average of voltage or use the voltage faults to increase the ramp each time you get one. Of course this SW stuff is just doing the same thing as teaching the drivers to be a bit smoother on the stick. Also, SW can't fix loss due to long wires, weak crimps, or excessive loss due to friction, and those mods are of course way better than simply avoiding deep voltage dips.
If you want to do a ramp, the PID palette has an output limiter or you can build your own. Greg McKaskle |
I'll second this. Joystick ramping is a really simple way to avoid voltage dips that can cause brownout. We always use this code for each of our motors. If you make the rate large enough (we usually allow dead stop to full speed in .1 seconds) the drivers won't even notice.
If you make the rate large enough...
#10
How do you program this in java? Do you just use the getVoltage() method from the PDP class.. does that method give you the information you need use joystick rampinG?
#11
If not, just use something like this: http://www.chiefdelphi.com/forums/sh...19&postcount=5 |
#12
You are correct. I have edited my previous post. I got it backwards because in our code we don't refer to the rate itself, but rather the time it takes to go from 0 to full, like how I described above. So our full speed time (as we call it) must be made small enough so that the drivers do not notice.
