Go to Post Those four stages will most likely be supplanted with the more aptly named phased approach: "Don't Panic", "Consider Panicing" and "Why havent we been panicing?" - Dan Richardson [more]
Unread 14-02-2016, 15:31
driesman driesman is offline
FTC #4318 (Green Machine Reloaded)
Rookie Year: 2010
driesman is an unknown quantity at this point
[FTC]: I2C Extension Cables
Hi - Anyone know where one can get extension 4-wire I2C for Modern Robotics hardware? The team is trying to use a color sensor, but the cable is too short. They need about 12 inches. Alternatively, a source for male and female connectors would be fine and the team can build an extension cable (though pre-made would be best). Thanks.
Unread 14-02-2016, 16:08
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: [FTC]: I2C Extension Cables
Vex has them for the Vex EDR line.
http://www.vexrobotics.com/extension-cables.html
The 4 wire ones come 12" long.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 14-02-2016, 17:02
Rookie Year: 2010
Thanks Foster. Found them!
Unread 15-02-2016, 12:54
jbartig jbartig is offline
jbartig is an unknown quantity at this point
Modern Robotics now has extension cables and pigtails:
http://www.modernroboticsinc.com/sensor-pigtail-kit
http://www.modernroboticsinc.com/sensor-extension-kit
Note that the Vex extension cables may need to have a side tab cut/sanded in order to fit in the connector. I haven't ordered any of the Modern Robotics extensions, but I'm guessing they don't have this issue.
Unread 15-02-2016, 14:28
The modern robotics ones are about 9.5" long, driesman was looking for ones about 12" long. But they are lots cheaper than the VEX ones.
