Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
Unread 14-02-2016, 18:36
Chemical Chemical is offline
FRC #2883
Chemical is an unknown quantity at this point
Vision Tracking and Lining up?
Hello all. I was looking for help with Vision tracking and continuing into lining up the robot automatically. I have successfully found the "U" shape around the bottom of the tower and it gets tracked correctly.
Firstly, I looked it up online and found some nice tutorials on how to it to register the box and mask it. However, I can not seem to figure out how to save the IP address in the vision processing vi in LABview. I want to be able to auto line up eventually. Any thoughts?
Unread 15-02-2016, 10:19
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
Team Role: Coach
Rookie Year: 2011
aeastet is an unknown quantity at this point
Re: Vision Tracking and Lining up?
I am not sure what you are asking? If you are using the vision code it should automatically get the IP address. Are you trying to make the IP Address camera a default? Could you show a screen shot of what you are trying to do?
