Go to Post So, if you feel your team is at a disadvantage, or the playing field isn't level.... Do something about it. - AdamHeard [more]
Unread 14-02-2016, 18:50
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
Rookie Year: 2013
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
[Snippet] Using 2+ USBCameras with minimal bandwidth usage
Hey CD,
I updated my old code that worked with any type of camera to be a bit more extendable, but it only works with USBCameras now.
Imports:
Code:
import java.util.ArrayList;
import com.ni.vision.NIVision;
import com.ni.vision.NIVision.Image;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.vision.USBCamera;
Variables:
Code:
 * The image to push to the CameraServer
private Image frame;
 * The list of all attached cameras
private ArrayList<USBCamera> cams;
 * The index of the current camera we are looking at
private int currCam;
 * The current camera we are viewing.
private USBCamera cam;
 * The maximum fps for all of the cameras
private final int MAX_FPS = 15;
 * The quality of image to push back to the driver station. Lower numbers save more bandwidth (0-100)
private final int QUALITY = 10;
 * Time to sleep after changing camera views. This is to prevent errors as USBCamera.startCapture() returns before it is ready to be seen
private final long SLEEP_TIME = 100;
init Code:
Code:
cams = new ArrayList<USBCamera>();
frame = NIVision.imaqCreateImage(NIVision.ImageType.IMAGE_RGB, 0);
currCam = 0;
CameraServer.getInstance().setQuality(QUALITY);
for(String s: /*Array of camera names*/){
	addCamera(s);
cam = cams.get(currCam);
cam.openCamera();
cam.startCapture();
addCamera method:
Code:
 * Adds the camera to our list to switch between and sets the FPS max
 * @param camName The name of the camera
private void addCamera(String camName){
	USBCamera temp = new USBCamera(camName);
	temp.setFPS(MAX_FPS);
	cams.add(temp);
	temp = null;
Loop code:
Code:
cams.get(currCam).getImage(frame);
CameraServer.getInstance().setImage(frame);
Switching Method:
Code:
 * Switch to the next camera in our ArrayList
public void switchCamera(){
	try{
		cam.stopCapture();
		cam.closeCamera();
		currCam++;
		currCam %= cams.size();
		cam.openCamera();
		cam.startCapture();
		Thread.sleep(SLEEP_TIME);
	}catch(Exception e){
		e.printStackTrace();
As always, feel free to post below or send me a PM if you need help!
Unread 20-03-2016, 15:45
zeldathegood zeldathegood is offline
FRC #4277
zeldathegood is an unknown quantity at this point
Re: [Snippet] Using 2+ USBCameras with minimal bandwidth usage
Thanks for posting the code. We gave this a try yesterday but kept getting no robot code after we deployed the code. We didn't have time to debug. We will try again on Monday.
