Re: Bumpers sticking out 1" beyond frame perimeter
Edit: I just skimmed the rest of the thread and apparently this was a needed clarification! |
First I think you can see how difficult answering questions on the Q&A can be based on this discussion.
As to the bumpers, mounting blocks, protrusions, etc. An inspector must determine the FRAME PERIMETER before making any decisions based on FRAME PERIMETER as a reference. In WCD, the frame is determined by frame extensions between wheels that will be used to support the bumpers. Whatever the design for bumper support, the FRAME is examined for openings and gaps that are greater than 8" wide or more than 1/4" deep, FRAME that is 8" or greater wide as measured from each corner and hardware extensions from the FRAME PERIMETER that do not exceed 1/4". When these determinations have been made, then and only them can a bumper design be evaluated. In my understanding of the OP, it is their intention to add blocks to the back of the bumpers to position the bumpers out 1" from the FRAME. On the surface this sounds illegal. A legal design would be to mount the blocks and/or a plate on the robot chassis which will then be evaluated for FRAME PERIMETER. These blocks can be used as long as they are less than 8" apart and satisfy all the other rules like the 1/2" minimum support at each end of the bumper. No matter what you design, you cannot ignore the gap rules in the FRAME PERIMETER as shown in Fig. 4-9, R26, or Team Update 05. Clearance holes are intended to allow teams to get a nice tight fit of their bumper system to the frame of the robot when they have hardware protruding outside of the frame for things like bolts used to hold the wheels and spacers on the kitbot chassis. In no case will clearance holes be allowed for motors as you describe. In that case, the FRAME PERIMETER is actually the motor in the resting position and that now would be the reference for bumpers that must be mounted on the FRAME PERIMETER. While we are on the subject, if your team is using the kitbot chassis and they are using the standard bolts for wheel axles, please remember that the nylock nut and washers go on the inside of the chassis. The bolt should be mounted so that the head is facing out. The standard bolt head is less than 1/4". That is one of the intentions of the 1/4" gap rule for bumper mounting. If a team still wants to mount their bumpers with no gap, then the bumper can have clearance holes to reduce the 1/4" gap caused by the "bolt heads" as stated in R21.B. |
As for fasteners it looks like an up to 1" gap is allowed as the picture shows a 2" gap as not allowed meaning to me at least a smaller <= 1"gap is otherwise there is no point in that picture. The gap is spanned not by "hard parts" but by fastners. Last edited by Boltman : 14-02-2016 at 21:29. |
Why would it matter if your mounts are part of the bumpers vs. the robot frame if the exact position of the bumpers is on the frame perimeter? This allows robots to meet weight requirements and moving the weight of mounts to the bumpers who has a max weight of 20lbs. We have done this for years and passed inspection before. |
But the implementation specifically called out WAS a change from the norm. Specifically, the bumpers (other than the mounts) were NOT on the Frame Perimeter. As in, the normal, standard, FRC bumper, that we all know and love, was being proposed to be mounted on blocks, as is normal on the sides of a West Coast Drive, except that the blocks would be mounted on the bumper, and THEN mounted on the front of the robot (you know, where the classic WCD has a frame member nicely defining the Frame Perimeter). And therein lies the problem. R20, Blue Box: If a multi-part attachment system is utilized (e.g. interlocking brackets on the ROBOT and the BUMPER), then the elements permanently attached to the ROBOT will be considered part of the ROBOT, and the elements attached to the BUMPERS will be considered part of the BUMPER. Each element must satisfy all applicable rules for the relevant system. (Emphasis mine) EDIT: I've attached two pictures. One is of the WCD "standard" bumper mounting, with the attachment points being hardmounted to the robot. The other is of the proposed bumper mounting, with the attachment points being on the bumper. One is legal. One is not. And the legal one would extend the frame perimeter, which per the OP would make the robot illegal under a different rule altogether. Last edited by EricH : 15-02-2016 at 00:28. |
Ours is a different case. Our frame perimeter is not extended, but instead our bumper has attachments that extend into the frame perimeter resting on a flat point, providing the bumper support that the 8" rule asks for. This allows us to transfer the weight of robot mounting points to the bumper weight instead. Its also easier when removing the bumper, because it is already being fastened at other points. The main purpose for doing this was to meet the bumper support rules while not adding to the weight of our robot for certain sections on the side of our robot. Again, our bumper is mounted on the frame perimeter. Last edited by waialua359 : 15-02-2016 at 00:56. |
Actually, ours serves another purpose, but I cant say.....yet. ![]() |
#10
"Inside" the frame perimeter, not outside.
#12
Mounting brackets that reach inside the FP are allowed (Q744), but if extensions of the "chassis" cause the hard parts of the bumper to extend more than 1" outside the chassis, the extensions to at least within 1" of the edge of the hard harts of the bumper must be permanently mounted parts of the FRAME PERIMETER for the configuration to be legal. |
#13
Glenn and the OP ARE describing completely different situations. Please be careful not to overlook the context in your eagerness to help.
