Go to Post Only a few more days till i get to see her again! This is sad you would think I was talking about a chick... no wonder my gf gets jealous. XD - sportzkrazzy [more]
Unread 15-02-2016, 12:22
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Rookie Year: 2012
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Losing connection when ramping over defenses
Has anyone else experienced this? I have checked and made sure that all of the wiring is good on our robot, yet every time we ramp over a defense (i.e. rock wall) and slam down, our robot drops connection. All wires are secured and locked in to their ports (power, ethernet, pwm, etc.)
Could this be a result of shock causing the radio/roboRIO to reboot?
If you have had this problem, please share your solutions.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 15-02-2016, 12:42
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Losing connection when ramping over defenses
Check your main breaker to make sure it isn't bad. There are a couple each year... With the bad ones, you can tell by lightly tapping on the red button while watching the LED's on the robot - with a bad one they'll flicker.
My team's main breaker was bad, but in a different way- the lever inside that lets you turn it on was broken. Brand new, out of the box for may be a day. It was the only one I've seen broken like that. Fortunately, we had a few spares sitting around
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 15-02-2016, 12:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
We had this happen to us a few times Saturday during our first test drives over the defenses. We are going to do trouble-shooting this evening. I also saw another thread that described a similar (possibly the same) problem.
Unread 15-02-2016, 23:17
evanperryg's Avatar
evanperryg evanperryg is offline
still doesn't like half champs
AKA: Evan Grove
FRC #4536 (The Minutebots)
Rookie Year: 2011
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
We had the same issue a couple years ago, had to mash the lever or a little bit of vibration would cut power to the bot. OP, if it isn't your breaker, check to see if the power cable for your router is firmly attached. We found that those hard impacts can cause it to get loose unless securely mounted. If it's available to you, I strongly suggest a 3D printed holder for the plug to keep it well secured.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 15-02-2016, 23:25
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
We have been having this issue, and I think ours came from the voltage supply blacking out. We plan to modify our drive train so that hopefully it won't recur.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 15-02-2016, 12:43
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Double check that the fuses on the PDP are full inserted. They can look good but are actually far from fully mating. Are you getting just a very short (one or two seconds) drop or are you getting a radio reboot?
Al
WB9UVJ
www.wildstang.org
________________________
Unread 15-02-2016, 12:47
Landonh12's Avatar
270 points
AKA: Landon Haugh
Rookie Year: 2012
It seems like a radio reboot, I'm just speaking from what the students have told me. It goes down for a good 30 secs.
I'll check the main breaker as well. Thanks guys.
Unread 15-02-2016, 12:49
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
What do you learn from the driver station logs? http://wpilib.screenstepslive.com/s/...og-file-viewer
Unread 15-02-2016, 12:53
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
Rookie Year: 2012
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
We have been experiencing this exact same issue. When we go over the defences we drop connection. We have isolated the issue to the roborio. We're still trying to figure out how to fix it. We're currently trying to add suspension to our roborio and hoping that fixes it.
Unread 15-02-2016, 12:55
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
What power plug in to the radio are you using? Wiggle it. If you do not get stable power, that might be your problem.
Unread 15-02-2016, 12:56
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
We had this happen last night too. The power connector for the radio came unplugged while going over the rock wall.
Landonh12's Avatar
270 points
AKA: Landon Haugh
Rookie Year: 2012
I haven't personally seen any of the logs, but I can check when I get to the meeting this afternoon. Usually there aren't any errors from what I've seen, but I could be wrong.
Unread 15-02-2016, 13:35
Procolsaurus's Avatar
Procolsaurus Procolsaurus is offline
AKA: Robert Pond
FRC #4118 (Roaring Riptide)
Rookie Year: 2011
Procolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really nice
We had very similar comms issues, which were solved by checking the fuses.
2011-2012 Team 180 student
2014-Now Team 4118 College Mentor
2014 Referee, 3 events
2015 Field Reset, Referee, Scorekeeper
Unread 15-02-2016, 16:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Those minifuses are very good at pretending to be fully seated when they really aren't. My advice to teams for getting them in all the way:
  • Push them in all the way.
  • Let go and notice how they look like they're in all the way.
  • Push harder. Literally until it hurts.
  • Notice that they go in a lot more.
As a rule of thumb (!), if you can pull them out with your fingers they aren't pushed in hard enough.
  #15   Spotlight this post!
Unread 15-02-2016, 16:55
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
If your using a two speed transmission check to make sure your in low.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
