Go to Post You know you've been involved with robotics too long when you see a remote-controlled traffic barrel coming up behind people and honking - and it doens't faze you. - GaryVoshol [more]
Unread 15-02-2016, 16:27
UnTrustedTruss UnTrustedTruss is offline
Local Nutter
Rookie Year: 1492
UnTrustedTruss will become famous soon enough
Nav X error
My programming team has been running into an issue with the nax mxp libraries. We have been trying to use the robot example that comes with the c++ download for the imu. However after much difficulty with the libraries it is now throwing a single error on the imu inizilation. On imu = new IMUAdvanced(serial_port, 50); it says "invalid new-experssion of abstract class type 'IMUAdvanced.' " Do you guys have any ideas of what we might have done wrong or could otherwise fix this issue?
Unread 15-02-2016, 21:15
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Nav X error
With the NavX, I believe you should be using the AHRS class. See the NavX docs: http://www.pdocs.kauailabs.com/navx-...o-libraries/c/
