Go to Post You're here for them, not for you. - Chris is me [more]
Unread 15-02-2016, 17:27
Mr. Ackroyd's Avatar
Mr. Ackroyd Mr. Ackroyd is offline
FRC #3044 (OxBe4)
Team Role: Coach
Mr. Ackroyd is on a distinguished road
Major failure with brecoflex belts
Wondering if any teams using the brecoflex flex treads have had delamination issues??
We had two spots delaminate while the bot was on the school hallways. We then tested on the carpet at a practice field and had those spots turn into five inches.
Unread 15-02-2016, 18:02
jfox100 jfox100 is offline
GameAnnouncer: Dallas,Bayou, Champs
FRC #1255 (FRC1255 - Blarglefish)
jfox100 is a name known to alljfox100 is a name known to alljfox100 is a name known to alljfox100 is a name known to alljfox100 is a name known to alljfox100 is a name known to all
Re: Major failure with brecoflex belts
Attachment 20086
ours are still good. Are those from this years Rhino Track kit from AndyMark? why are they green?
Unread 15-02-2016, 18:34
FRC #3044 (OxBe4)
Team Role: Coach
No, we deigned our own system and got the tracks from the brecoflex company. We do have backup treads and I am sending these back to be reworked
Unread 15-02-2016, 20:52
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Not brecoflex specific, but most belts don't like having their bend reversed, so if you have somewhere in your belt path that you're reversing it, that could be a problem. Also if you're exceeding the minimum bend radius in your belt path.
Unread 15-02-2016, 21:21
FRC #3044 (OxBe4)
Team Role: Coach
Thanks for the info but the bend radius is proper and it's not reveresed. I talked with the company earlier and the green traction is heat welded to the treads. Brecoflex had a huge run on belts this year and I'm afraid some batches may have been hurried to get shipments out.
