Go to Post what hint? - Electricia 1599 [more]
Unread 15-02-2016, 19:54
chaparoel chaparoel is offline
FRC #4635
chaparoel is an unknown quantity at this point
pneumatics module/robot inspection
Hello,
This year our team is not going to use pneumatic so we have the question that if it is obligatory to put the pneumatic control module to pass the inspection.The issue is that we currently only have a burned control module so we are seeing if we need to get another in order to pass inspection.
Thank you very much
Unread 15-02-2016, 19:56
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Re: pneumatics module/robot inspection
No it is not necessary to have the PCM on your robot.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 16-02-2016, 00:20
smitikshah's Avatar
smitikshah smitikshah is offline
Drive Coach
AKA: Smiti
FRC #2869 (Regal Eagles)
Team Role: Coach
Rookie Year: 2015
smitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond repute
That's weird. Our team had the same problem where our PCM randomly stopped working... We replaced it with a new PCM and it started working fine so yeah...
Unread 16-02-2016, 00:21
dmaggio744's Avatar
dmaggio744 dmaggio744 is offline
Drew Maggio
AKA: Drew Maggio
Rookie Year: 2015
dmaggio744 is an unknown quantity at this point
We ran into a similar problem, as stated by my teammate.
Maybe try asking around? We also practiced at another team's field today, and we are using their backup for now.Once ours is shipped, we will replace their backup with our new one.
Also, any idea how yours blew? I'd hate to have it happen again if it was preventable...
Unread 16-02-2016, 07:45
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
R88 The pressure switch requirements are:
A. It must be Nason P/N: SM-2B-115R/443
B. It must be connected to the high-pressure side of the pneumatic circuit (i.e. prior to the pressure regulator) to sense the “stored” pressure of the circuit.
C. The two wires from the pressure switch must be connected directly to the pressure switch input of the PCM controlling the compressor or, if controlled using the roboRIO and a Spike relay, to the roboRIO.
D. If connected to the roboRIO, the roboRIO must be programmed to sense the state of the switch and operate the relay module that powers the compressor to prevent over-pressuring the system.
The PCM is by far the easier method. If you don't use one, you do have to use a Spike Relay for compressor control. You may replace the 20 amp fuse with a 20 amp breaker for this application only. All other motors must only use the 20 amp fuse.
Al
WB9UVJ
www.wildstang.org
________________________
