Go to Post IRI seeks to invite the very best robots to play the FIRST game, achieving the highest level of play, while keeping in place the FIRST atmosphere. - Nathan Streeter [more]
Unread 15-02-2016, 20:44
ICE_Bear ICE_Bear is offline
FRC #5875 (ICE)
Rookie Year: 2014
ICE_Bear is an unknown quantity at this point
Help program.
How do you program the POV on the Logitech joystick to move one motor using lab view?
Unread 15-02-2016, 21:24
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
Rookie Year: 2013
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Re: Help program.
On your joystick block, there should be an output for "POVs" which returns an array of integers. Index the first element of that array, and it'll give you the angle that the POV is being pressed. If nothing is being pressed, the value is -1.
Up is 0
Right is 90
Down is 180
Left is either -90 or 270; I don't remember
Head Programmer / Driver
Unread 16-02-2016, 17:45
FRC #5875 (ICE)
Rookie Year: 2014
Re: Help program.
How do you get to the joystick block?
Unread 16-02-2016, 22:45
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Help program.
It's one of the outputs available on the regular Joystick Get Values.
The same vi you use to get the axis and buttons in Teleop.vi.
Unread 17-02-2016, 20:19
FRC #5875 (ICE)
Rookie Year: 2014
Re: Help program.
How do you program the POV to move a motor up and down? sorry we don't have much experience with lab view.
Unread 17-02-2016, 21:45
Just Itinerant
Re: Help program.
I don't have a joystick with a HAT in the shop I'm in right now, so I won't be able to test this until tomorrow at the earliest, but this is the idea.
Unread 18-02-2016, 21:00
FRC #5875 (ICE)
Rookie Year: 2014
Re: Help program.
What is the box at the bottom of the diagram labeled POV and how do you add it?
Unread 18-02-2016, 21:24
Just Itinerant
Re: Help program.
That's not actually necessary.
It is called an indicator and just gives us a display on the front panel of the live values of POV when you run the code in Debug.
You get it by right-clicking on the wire or output node on the vi and choosing Create->Indicator
Unread 19-02-2016, 17:15
FRC #5875 (ICE)
Rookie Year: 2014
Re: Help program.
How do you connect the POV to PWM 4?
Unread 19-02-2016, 19:34
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Help program.
The snippet Mark posted shows how to control any motor you like. He called it "Motor 1" in his example. You can call it whatever you want in the string wired to the Refnum Get. Just Open it as PWM4 in Begin, and wire the device reference to a Refnum Set with the same name.
Unread 19-02-2016, 20:01
FRC #5875 (ICE)
Rookie Year: 2014
Re: Help program.
how are you supposed to do that in Begin.vi?
