Go to Post [when asked where to learn about robot parts] ...some forum called Chief Delphi. I hear the people there are pretty knowledgeable about this robotics thing. - EricH [more]
Unread 15-02-2016, 20:51
narmality_rules's Avatar
narmality_rules narmality_rules is offline
Jack of all trades
AKA: Graham Cochrane
FRC #0296 (Northern knights)
Rookie Year: 2015
narmality_rules is an unknown quantity at this point
Position control without CAN?
Hello,
I'm curious to know if it's possible to keep something in a position even if force is applied (such as gravity) with only a Victor SP and encoder. Any help with the code is also welcome.
Thanks!
Unread 15-02-2016, 21:00
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
Team Role: Leadership
Rookie Year: 2013
JacobD is an unknown quantity at this point
Re: Position control without CAN?
Yeah you can, use a PID control loop. https://wpilib.screenstepslive.com/s...rs-pid-control
2013-2014: Electrical, Mechanical
2014-2017: Team Captain
Unread 15-02-2016, 21:39
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
Rookie Year: 2014
SamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud of
Jacob's answer is good. You could also use a standalone PID controller (rather than wpilib's subsystem). Lots of teams have written PID controllers, but I'm going to stick in a plug for mine.
Sam Fuchs
236 TechnoTicks, Old Lyme, CT
2015 - Programming, Electrical
2016 - Lead Programmer, Co-Driver
2017 - Lead Programmer, Co-Driver
Unread 16-02-2016, 01:01
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You only need PI control for keeping an arm in place. D isn't likely to help, so you can ignore it and keep its calibration constant at zero.
If you need to hold position against gravity, you might run into problems with overheating a stalled motor. A more sustainable solution is to use a counterweight or spring to oppose the force of gravity, so the motor doesn't have to be providing continuous torque at zero speed.
