Go to Post push for what you think is right... just do it in the right way - Andy Baker [more]
Unread 15-02-2016, 22:31
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
Trick for printing manual for 3 hole punching?
This sounds stupid, but for the life of me I can't figure out how to print the manual PDFs with different margins to properly clear a 3-hole punch. I'm trying to build a very good copy of all the documentation for my use, but I can't figure or a way to shift it. I know someone has to have a trick out there.
And yes, I could (and probably still will) load all the docs up to a iPad Mini, but after poking at this a few days, it's the principle of the thing!
Unread 16-02-2016, 06:45
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Trick for printing manual for 3 hole punching?
Spend a few dollars and take it to Staples or your local printing place. They can help with the alignment, and their three hole drills create a slightly larger hole.
If it's completed info check into their spiral bindings. One year I had them spiral bind the small chapters/sections and then three hole punch to fit them all into a 4" binder. Roboteers could take an individual section, use it without the loss or mixup of any pages and return it back to the master binder.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 16-02-2016, 09:41
Rombus's Avatar
AKA: Rick Kosbab
Thanks for the suggestion Foster, I'll probably do that next year, not worth the headache!
I actually tried something different this morning and so far its working. I tired PDF-XChange Viewer and it give me just enough options for it to work.
I ended up setting Page Scaling to "Fit to printer margins" then checked "Auto-Centre pages in sheets" and it givers just enough of a bump to clear the 3 hole punch I'm using. I had not tried another viewer! >.<
