Go to Post A true team can only be formed by people who care about each other and that have a common goal... - keehun [more]
Unread 16-02-2016, 10:31
tr6scott's Avatar
tr6scott tr6scott is online now
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
2016 Inspection Checklist and Firmware revisions.
From the 2016 labview install I have the following firmwares installed for the Cross the Road components:
Code:
"C:\Users\Public\Documents\FRC\PDP-Application-1.40.crf"
"C:\Users\Public\Documents\FRC\PDP-Application-1.40-EnableDurExtractWrkArnd.crf"
"C:\Users\Public\Documents\FRC\TalonSrx-Application-1.16-BoundsCheckAllowableClosedLoopErr.crf"
"C:\Users\Public\Documents\FRC\TalonSrx-Application-1.18.crf"
"C:\Users\Public\Documents\FRC\TalonSrx-Application-2.00.crf"
"C:\Users\Public\Documents\FRC\PCM-Application-1.65.crf"
"C:\Users\Public\Documents\FRC\PCM-Application-1.65-production.crf"
The Inspection list shows the following revs to be applied.
Code:
Firmware Versions – Software/firmware for devices is at or above listed versions below:
 Driver Station – 16.0.1 <R91>
 Jaguars – V109 <R70>
 roboRIO (Image - FRC_2016_v19 and Firmware – v3.0.0) <R56>
 PCM – 1.62 <R71>
 Talon SRX – V1.01 (cannot be greater than V10.0) <R70>
 PDP – 1.37 <R72>
So what firmware are we to be applying to this hardware?
The sooner we get behind schedule, the more time we have to catch up.
Unread 16-02-2016, 10:35
PayneTrain's Avatar
PayneTrain PayneTrain is online now
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Re: 2016 Inspection Checklist and Firmware revisions.
Code:
Code:
 PCM – 1.62 <R71>
 PDP – 1.37 <R72>
According to the FRC Screensteps, the current revision is not always the minimum required revision. It's probably beneficial to go ahead and update all of your hardware now in case the requirements are updated in a TU down the road (I'd expect it) but you just need the minimum requirements to get through inspection.
Unread 16-02-2016, 10:36
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is online now
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
Team Role: Leadership
Rookie Year: 2014
nickbrickmaster is an unknown quantity at this point
Inspection versions are minimum. I've heard of some problems with low talon versions and PID control.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 16-02-2016, 11:49
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Thank You!
Should read fine print, minimum versions.!
