Go to Post The short answer is there is no shortcut. - JDNovak [more]
Unread 16-02-2016, 12:06
CyberTeam5713 CyberTeam5713 is offline
FRC #5713
CyberTeam5713 is an unknown quantity at this point
How do i make my robot drive without the robot drive class
So far this is what i got.
Joystick mXboxController;
Joystick controlStick;
Talon frontLeft,frontRight, rearLeft, rearRight;
public void robotInit() { // this code will be ran each time we power on the robot
mXboxController = new Joystick(0); // depends on the usb connected to computer
controlStick = new Joystick(1);
frontLeft = new Talon(3);
frontRight = new Talon(2);
rearLeft = new Talon(0);
rearRight = new Talon(1);
public void autonomousInit() { // triggers when we enter autonomous
frontLeft.enableDeadbandElimination(false);
frontLeft.set(-1.0);// dont forget to change speed to an int value -1.0 is full reverse and +1.0 is full forward also for foward on the y value -1 this may vary REMEBER!!!
rearLeft.enableDeadbandElimination(false);
rearLeft.set(+1.0);
frontRight.enableDeadbandElimination(false);
frontRight.set(-1.0);
rearRight.enableDeadbandElimination(false);
rearRight.set(+1.0);
public void autonomousPeriodic() { // this code runs periodically in autonomous
while (isAutonomous() && isEnabled()) {
public void teleopInit(){ // This triggers every time we enter telop mode.
mXboxController = new Joystick(0); // the number within the parathesis depends on the controllers usb order always check
while (isOperatorControl() && isEnabled()) {
if(mXboxController.getRawButton(8)){
} else if(mXboxController.getRawButton(7)){
if(mXboxController.getRawButton(5)){
rearLeft.set(0.1);
} else if(mXboxController.getRawButton(6)){
rearRight.set(0.1);
Timer.delay(0.01); } }
Unread 16-02-2016, 13:01
Beeker's Avatar
Beeker Beeker is offline
AKA: Joe
FRC #4377 (BC. Blaze)
Rookie Year: 2015
Beeker is an unknown quantity at this point
Re: How do i make my robot drive without the robot drive class
// tank drive xbox controller no robotdrive class
frontRight.set(mXboxController.getRawAxis(5);
rearRight.set(mXboxController.getRawAxis(5);
frontLeft.set(mXboxController.getRawAxis(2);
rearLeft.set(mXboxController.getRawAxis(2);
Timer.delay(0.01);
