Go to Post I WANT MY POOF BALLS! - Cyber Punk 234 [more]
Unread 16-02-2016, 15:19
CyberTeam5713 CyberTeam5713 is offline
FRC #5713
CyberTeam5713 is an unknown quantity at this point
Tank Drive with one xbox controller
This is Tank Drive with one controller using left analog to control left drive train and right analog to control right drive.
RobotDrive Leftdrive;
RobotDrive Rightdrive;
Joystick mXboxController;
Joystick controlStick;
Talon frontLeft,frontRight, rearLeft, rearRight;
public void robotInit() { // this code will be ran each time we power on the robot
mXboxController = new Joystick(1); // depends on the usb connected to computer
controlStick = new Joystick(0);
frontLeft = new Talon(2);
frontLeft.setInverted(true);
frontRight = new Talon(1);
rearLeft = new Talon(3);
rearRight = new Talon(0);
rearRight.setInverted(true);
Leftdrive = new RobotDrive(frontLeft, rearLeft);
Rightdrive = new RobotDrive(frontRight, rearRight);
public void autonomousInit() { // triggers when we enter autonomous
public void autonomousPeriodic() { // this code runs periodically in autonomous
while (isAutonomous() && isEnabled()) {
Leftdrive.drive(0.5, 0.0);
Rightdrive.drive(0.5, 0.0);
Timer.delay(0.5);
Leftdrive.drive(0.0, 0.0);
Rightdrive.drive(0.0, 0.0);
public void teleopInit(){ // This triggers every time we enter telop mode.
mXboxController = new Joystick(0); // the number within the parathesis depends on the controllers usb order always check
controlStick = new Joystick(1);
while (isOperatorControl() && isEnabled()) {
Leftdrive.setSafetyEnabled(true);
Rightdrive.setSafetyEnabled(true);
Leftdrive.tankDrive(mXboxController.getRawAxis(1), mXboxController.getRawAxis(1));
Rightdrive.tankDrive(mXboxController.getRawAxis(5) , mXboxController.getRawAxis(5));
Timer.delay(0.01); } } // this will constantly update motors and speed controllers periodically
At the speedcontroller setInverted you do not have to invert the controller thats just how ours was set up
