Go to Post "The hardest part about building the robot is figuring out what to build..." - Jeff Waegelin [more]
Unread 16-02-2016, 20:05
person1163 person1163 is offline
AKA: Varun
FRC #5511 (Cortechs)
Rookie Year: 2014
person1163 is an unknown quantity at this point
Reading Published Values from External Application
In my Labview Project, I am trying to read data published to the Variable tab in the Dashboard from an external application (GRIP). It is in the folder GRIP, and the subfolder Contours.
How can I get the value to a global variable? I found the block to read data, but I don't know why it isn't working.
Thanks in Advance.
Unread 17-02-2016, 08:20
Greg McKaskle Greg McKaskle is online now
Re: Reading Published Values from External Application
Depending on how it was stored, it is either in /SmartDashboard/GRIP/Contours or in /GIP/Contours. The easiest way to see is to use the variables tab of the dashboard or another table viewer to compare the variable name. And remember that they are case-sensitive too and need to be read as the correct type ( number as number, string as string, etc.)
Greg McKaskle
Unread 19-02-2016, 22:34
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Thanks in Advance.
Someone actually wrote a wiki article on using GRIP with LabVIEW.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
