Go to Post Although you will see lot's of people complain about parts (sometimes that includes me) all of us are held to the same constraints. That's what makes this so much fun. - Al Skierkiewicz [more]
Unread 16-02-2016, 20:48
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Sprockets on a bearing?
Is there such a thing as a sprocket on a bearing? The purpose is to have a lever on the same hex shaft of something else, but the lever is controlled by an external force, and not the movement of the hex shaft itself. it just uses the hex shaft as a structure.
Unread 16-02-2016, 20:57
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Re: Sprockets on a bearing?
Sure, just use a hex bearing from AndyMark or VexPro and put a 1.125" hole in your lever (or sprocket) and Bob's your uncle.
Dr. Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 16-02-2016, 21:03
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Dr. Joe J.
Will try that, and second question. What is the best way to directly attach a sprocket to the lever. The normal way is running a hex shaft through the sprocket into the lever, but obviously that's not a option in this case.
Unread 16-02-2016, 21:16
Owen Busler's Avatar
Owen Busler Owen Busler is online now
Build Captain
FRC #0303 (Test Team)
Team Role: Leadership
Rookie Year: 2014
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
We have something very similar on our robot, but we used gears.
http://www.vexrobotics.com/vexpro/mo...sprockets.html
Take a look at those plate sprockets. With those you will be able to put a bearing in the middle, and use the 1.875 inch bolt circle to attach to your rotating lever. This will allow the shaft to spin independent of the plate the sprocket is bolted to.
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 16-02-2016, 21:26
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
We have some of these on order, but they won't be in until monday. A local team is hosting a practice competition day this saturday, and we need to gerry rig something before then, just to get a feel for it. Right now I'm thinking drill into a sprocket, make it wide enough for a bearing , and then put spacers between the lever and the sprocket (to make room for the chain), and drill holes into the side of the sprocket and lever, and just run long bolts through them.
Some one PLEASE tell me if there is a better idea that i can do with just normal sprockets, hex bearings, screws, and a drill bit
Unread 16-02-2016, 21:27
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
If there is a "standard" bolt pattern in first it is the 6 screw pattern on the wheels, sprockets, hubs and such, specifically, 6 clearance holes for #10 screw (.196" or .200" depending on how much slop you are feeling that day) on a 1.875" bolt circle.
The hex hubs from AndyMark and VexPro both use that pattern. VexPro has additional torque transfer norkers (that's a technical term ;-) that fit into mating holes in there sprockets and wheels. They are really nice for some applications. They are overkill in others.
I typically don't use the VexPro norkers but sometimes I do. If I need more torque than I feel comfortable putting on the 6 bolts themselves, then I usually use a larger sprocket and put hole out farther on the sprocket to transfer the torque to the lever.
YMMV.
Dr. Joe J.
Mentor
Team #88, TJ2
Unread 16-02-2016, 21:41
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
YMMV.
Dr. Joe J.
VEX's standard is actually 6 #8s on the same size bolt circle. A lot of teams who have already standardized on #10 bolts just drill them out.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 16-02-2016, 21:46
Bob Steele's Avatar
Bob Steele Bob Steele is online now
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
FYI This type of application is called a "dead axle" You can certainly use the same axle to run a number of different spockets this way, each with their own power by chain or belt. It is used successfully by many teams.
Good luck!!
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 16-02-2016, 21:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
do you mean an idler sprocket?
McMaster Carr has these....
