Go to Post "its not working because you didnt program it right" *wheel falls off* "never mind" - Nin_estarSaerah [more]
Unread 02-16-2016, 08:55 PM
darklink2458 darklink2458 is offline
FRC #4915 (Spartronics)
Rookie Year: 2015
darklink2458 is an unknown quantity at this point
Talking Drop down menu in SFX
Hey Chief Delphi I'm having trouble with making a drop down menu in SFX (smart dashboard 2.0) thanks for any help you can give me
Unread 02-16-2016, 09:39 PM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Drop down menu in SFX
You can use a SendableChooser
http://first.wpi.edu/FRC/roborio/rel...leChooser.html
https://wpilib.screenstepslive.com/s...smartdashboard
Unread 02-16-2016, 10:01 PM
Rookie Year: 2015
Thanks but we have already tried that when we use this it returns the default values
Unread 02-17-2016, 09:47 AM
mreynolds's Avatar
mreynolds mreynolds is offline
Team Captain | Head of Controls
AKA: Matthew Reynolds
FRC #4946 (The Alpha Dogs)
Rookie Year: 2014
mreynolds is an unknown quantity at this point
The sendable chooser is the easiest and most reliable way of doing this, I can help you debug your code if you want, you can post it in a paste bin or GitHub if you want
Unread 02-21-2016, 10:45 AM
An Outlier An Outlier is offline
AKA: Julian Bernard
FRC #5687 (The Outliers)
Rookie Year: 2015
An Outlier is an unknown quantity at this point
I have had abundant problems with this widget, but after painstaking repetition, I have developed a solution. Please follow the below steps EXACTLY to ensure you get the same results!
1) Make a new Tab in the SFX - Dunno why, but just safer to start fresh
2) Click the "+" or "add" tab, and drag in the Options array from your SendableChooser
3) Double-click the SendableChooser to edit the widget, and copy the Path EXCEPT for the "/options" part. This should look something like "SmartDashboard/AutonomousMode/options". ONLY COPY the "SmartDashboard/AutonomousMode"
4) Add another widget, ComboBox
5) Edit the ComboBox widget and paste the path.
6) Should be good to go! Make sure to press the "Play"/Green arrow to interact with the chooser
Unread 02-29-2016, 10:36 AM
Joe Derrick's Avatar
Joe Derrick Joe Derrick is offline
Mentor - Programming
FRC #0319
Rookie Year: 2011
Joe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of light
Smile Re: Drop down menu in SFX
Worked for us thank you
2010-2017 Mentor Team 319
2012 - Rockwell Automation Award Winner
2014 - Xerox Creativity in Engineering Winner, Archimedes Division
2015 - Rockwell Automation and Gracious Proffesionalism Winner, Tesla Division
2016 - North Shore and UNH District Event Winner, Carson Division
http://www.frc319.com
Unread 03-23-2016, 07:08 PM
tcjinaz tcjinaz is offline
Tim
FRC #3853
Rookie Year: 2011
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
We're not seeing the morph option. What did we mess up?
Software Mentor
3853 Pridetronics[
Unread 03-30-2016, 07:06 PM
Rookie Year: 2015
No the morph button has not been working on our smart dashboard either
Unread 03-31-2016, 01:17 AM
Tim
FRC #3853
Rookie Year: 2011
Very disappointing. Now we stick to SmartDashBoard. Or, we make the leap back to that fantastic GUI construction system available in the LabView DashBoard.
I am not happy about the BeerHall Putsch that forced me to Java this year.
T
Software Mentor
3853 Pridetronics[
