Go to Post After all, when any student is isolated because of a difference - because of race, gender, social beliefs, or ideological concepts - we all lose. - MysterE [more]
Unread 17-02-2016, 08:20
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Bumper Backing Question
R26 BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-9). To be considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERMIETER.(emphasis added)
Question: What is considered "backed"?
Scenario:
1) Chassis height is 2-4.5" off the ground.
2) Chassis is a full Rectangle, not U shaped.
3) At least 8" of Bumper is mounted at each corner of the Chassis with the bottom at the 4" level per rule R22 Bumper Zone (4-12"). So, the entire bottom 1/2 inch of the Bumper is backed by the Chassis.
4) At the end of each Bumper, the Bumper is only supported by the Chassis
5) There is no portion of the Bumper that is more than 1/4" away from the Chassis. There is no gap at each end of the Bumper.
Question: Does the proposed Bumper satisfy the rules?
Seems like it meets the literal definition of R26. R26 does not state a minimum height that the Bumper must be in contact with the Frame Perimeter in order to be considered "backed".
Note: There are occasional pillars that further support the Bumpers to keep them from rotating if it is hit higher than the chassis line. The Chassis will keep the Bumpers from moving in the Yaw Axis, and the pillars will keep the Bumpers from moving in the Pitch Axis.
In prior years, we used the Andymark Kit Chassis, and that had 1.5" contact with the Bumper. We never thought about how little contact we needed to have in order to meet the rule. Due to placement of other items on the Chassis Frame, it would be difficult to have Pillars at each Corner, and at the 8" end for the 8" Bumper segments.
Unread 17-02-2016, 08:30
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
Rookie Year: 2012
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
Re: Bumper Backing Question
We have a similar situation with our bot. As far as we can tell it is legal. However what happens when someone with taller bumpers hit the top portion of your bumpers. Are they strong enough that the will not bend in?
FRC Rebound Rumble | Ultimate Ascent | Aerial Assist | Recycle Rush | FIRST Stronghold | FIRST STEAMWORKS
FLL Senior Solutions | Nature's Fury | Trash Treck | Animal Allies
Unread 17-02-2016, 08:46
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
There is no defined minimum amount of contact with the frame to satisfy the "backed" rule. Inspectors are really looking for something that can withstand rigorous gameplay, and this includes robots with bumpers at a different height hitting you, and hitting you hard.it's in your best interest to make sure your bumper can withstand that interaction... if your plywood breaks, or your mounting system snaps, then you're sidelined until you can get it fixed. And that may require a trip to the hardware store for more plywood!
For what it's worth, the old c-channel frame usually only had 1" of material backing the bumpers.
This year my team has the bottom 1 1/2" backed, with vertical supports extending another 1 1/2" every 6" or so.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 17-02-2016, 08:56
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Rich,
The supported/backed by frame and the gap rules are simply to prevent bumper failure. Larger gaps and no support lead to bumper failure as Jon stated above. As inspectors we want you to play in as many matches as you want. If your bumper system fails, other damage to the robot is likely. We want you to play.
Al
WB9UVJ
www.wildstang.org
________________________
