Go to Post You can never take enough precautions when it comes to safety. Please, be prepared for anything. - Tom Bottiglieri [more]
Unread 17-02-2016, 08:34
JakeTheGreat JakeTheGreat is offline
FRC #2876
JakeTheGreat is an unknown quantity at this point
Using Limit Switches plugged into TalonSRX
My team has plugged a limit switch into the data port on a TalonSRX and I can't find out how to get its value. Is there a method in CANTalon or something that we can use? Thank you.
Unread 17-02-2016, 09:25
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Re: Using Limit Switches plugged into TalonSRX
Yes, there are methods to enable the limit switches and to read them back. They are particularly useful when you want to make sure the motor stops when the switch is hit.
Here's a sample blurb of connecting them:
Code:
// Construct instance
CANTalon lift = new CANTalon(12);
// Make available in "Test" mode
LiveWindow.addActuator("Lift", "Motor", lift);
// Enable hardware limit switch at both ends of lift so lift stops
// Make sure you connect them correctly!
lift.enableLimitSwitch(true, true);
There are two limit switch connections (one for stopping the motors from driving forward and one for stopping them from driving in reverse). It is important to connect them correctly in order to get the hardware feature working properly.
Here's a sample of checking in software if the switch has been hit
Code:
boolean atTop = lift.isFwdLimitSwitchClosed();
boolean atBottom = lift.isRevLimitSwitchClosed();
There are a bunch of methods available on the CANTalon speed controllers (they have many more features than most of the other speed controllers).
You should be able to find the javadoc for them on your system (comes with the WPIlib plugins). Look for the javadoc under (change YOUR_LOGIN_ID to the login you use on Windows):
file:///C:/Users/YOUR_LOGIN_ID/wpilib/java/current/javadoc/index.html
Beware of the "soft limit" functions. I'm not sure of the practical use, but we had some of the programmers set or enable both of the "soft limit" switches. This seemed to stick and prevented the CANTalon from working with other code that was not using the "soft limit" functions. Some of our team thought the CANTalon had gone bad and physically replaced them. We were lucky and pulled them from the trash and then discovered that the soft limits had been enabled on the ones mistaken for bad.
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
Rookie Year: 2011
TimTheGreat will become famous soon enoughTimTheGreat will become famous soon enough
If it's forward limit switch it should be
Code:
motor.isFwdLimitSwitchClosed()
for the reverse limit switch it should be
Code:
motor.isRevLimitSwitchClosed()
P.S Nice username
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 17-02-2016, 17:42
FRC #2876
Thank you guys, this helped us greatly!
