Go to Post Teams are overconfident every year. Honest evaluation of your capabilities with regard to your design strategy is a skill few teams have. - Chris is me [more]
Unread 17-02-2016, 09:27
VrewDaive VrewDaive is offline
FRC #4284
VrewDaive is an unknown quantity at this point
pneumatics help, noob programmer.
Hey everyone! this is our first year using really any kind of pneumatics, our team has all of the hardware, (PCM, Compressor, DoubleSolenoids etc) what we would like is the basic understanding of the coding side of things, i understand that you need to write the PCM in CAN, im really unsure of what that entails. here is the code right now
Code:
	     * This function is run when the robot is first started up and should be
	     * used for any initialization code.
	     */  RobotDrive myDrive, frontCatcher, backCatcher, windowDrive;
	    	Joystick moveStick;
	    	Relay Relay1, Relay2;
	    	//ADXRS450_Gyro scotbot;
	    	//Solenoid S;
	    	Compressor C;
	    	DoubleSolenoid DS;
	    public void robotInit() {
	    	Talon TalLF = new Talon(0);
	    	Talon TalLR = new Talon(1);
	    	Talon TalRF = new Talon(2);
	    	Talon TalRR = new Talon(3);
	    	Jaguar Window1 = new Jaguar(4);
	    	Jaguar Window2 = new Jaguar(5);
	    	//Talon TalCatcher = new Talon(4);
	    	//Talon TalCatcher1 = new Talon(5);
            //Talon TalCatcher2 =  new Talon(6);
	    	myDrive =  new RobotDrive(TalLF,TalLR,TalRF,TalRR);
	        //frontCatcher = new RobotDrive(TalCatcher,TalCatcher1);
            //backCatcher = new RobotDrive(TalCatcher1, TalCatcher2);
	    	windowDrive = new RobotDrive(Window1, Window2);
	    	moveStick = new Joystick(0);
	    	//scotbot = new ADXRS450_Gyro();
	    	DoubleSolenoid DS = new DoubleSolenoid(0, 1);
	    	Compressor C = new Compressor(0);
	    	Relay1 = new Relay(0);
	        Relay2 = new Relay(1);
	     * This function is called periodically during autonomous
	    		myDrive.mecanumDrive_Cartesian(1, 1, 1, 0);
	    		// catcherDrive.drive(1, 0);
	     * This function is called periodically during operator control
	    	C.setClosedLoopControl(false);
	       myDrive.mecanumDrive_Cartesian(moveStick.getRawAxis(0), moveStick.getRawAxis(1), -moveStick.getRawAxis(5), 0);
	       if(moveStick.getRawButton(3))
	    	   windowDrive.drive(1,1);
	       else
	    	   if (moveStick.getRawButton(2))
	    		   windowDrive.drive(-1,1);
but every time we enable the teleop it shorts out and exits very quickly.
Thanks
Unread 17-02-2016, 12:26
RayG RayG is offline
FRC #1796 (RoboTigers)
Rookie Year: 2012
RayG is an unknown quantity at this point
Re: pneumatics help, noob programmer.
On the new control system, the PCM has built-in closed loop control of the compressor, no code is necessary to turn it on
will disable closed loop control and the compressor will not turn on.
Unread 17-02-2016, 13:57
FRC #4284
So how do you communicate with the PCM? do you simly connect the can wires to it and the robo rio and your good to go? or do you have to put something in the code??
Unread 17-02-2016, 14:09
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
In general, you have to:
1) Create the pneumatics object (similar to how you create the talon, joystick, etc)
2) Enable the object
At that point, the library will automatically keep the system pressurized.
You would then control the solenoids.
You can disable, and the re-enable the compressor in order to turn it off when you don't need it, or want to minimize current draw (prevent brownout, or make more power available for the motors)..
Unread 17-02-2016, 14:10
cantdecide cantdecide is offline
FRC #5773 (YAFL Mechatronics)
Rookie Year: 2016
cantdecide is an unknown quantity at this point
Electrically, you have to wire up the PCM between the PDP and the roboRIO since it doesn't have an internal termination resistor. It goes:
